Power Steering issues - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Tech (https://cb4x4.com/forum-40.html) +--- Thread: Power Steering issues (/thread-2789.html) |
Power Steering issues - Crawdad - 06-09-2011 Thx Ben and Charles! I have a fella coming down from NC to buy the 5 aluminum rims I posted on Classic so I can use that money to buy the proper brackets, hose and v-groove pulley. I've dealt with one guy at Wild Horses and he may give me another deal if I buy all those items from them. Power Steering issues - broncosbybart - 06-09-2011 sounds like a plan! Power Steering issues - Crawdad - 06-22-2011 Nick @ WHs came thru with a discount but man shipping has gotten high. I got the shiney, silver brackets with plenty of hardware today. The saginaw pump came yesterday. So here is my problem, I tried to mate the pump with the bracket and I can only get one hole to line up??? Do I need to modify the bracket a little (at the pencil point)? Any suggestions would be helpful! Power Steering issues - Crawdad - 06-22-2011 Here are two pics of the front and rear of my saginaw pump. Yes I even dumbed it up for me with the colored pens/ pencils! I want to make sure which bolt will alow me to "clock" or rotate the PS pump. I really want to make sure I do not ruin this pump! Power Steering issues - blazinchuck - 06-23-2011 i dont believe you can clock that pump, thos bolts go through that housing and into the pump. i could be wrong, but i dont see how that will work. as for the bracket...yes, modify it. you look like you have a lil different style pump housing...vs the ole can ham look. will the pump and bracket not fit under the hood as they sit now? why clock it? Power Steering issues - Crawdad - 06-23-2011 blazinchuck Wrote:i dont believe you can clock that pump, thos bolts go through that housing and into the pump. i could be wrong, but i dont see how that will work. as for the bracket...yes, modify it. you look like you have a lil different style pump housing...vs the ole can ham look. will the pump and bracket not fit under the hood as they sit now? why clock it? Hey Chuck, I spoke with the fella that rebuilt my pump and he said my pump has a bigger reservoir b/c of the dual return. He said "most" single returns fit this particular bracket. No big deal I can mill out a slot next week. I have not installed it on the motor yet but it should fit well below the hood. I read on a Colorado Bronco website where a guy clocked/ rotated his but it must have been a single return. I don't even know how much truth it is to clocking a single return, only so much faith you can get from some people's threads! ![]() Power Steering issues - Crawdad - 06-23-2011 By next week I hope my WH PS Saginaw bracket will look like BC's PS Saginaw bracket. Notice the notch, hmmmmmm. Power Steering issues - Crawdad - 07-02-2011 I finished "modifying" the PS bracket. I fitted all up and works well on the bench. It appears I took out more than I needed to but oh well. I made a sleeve that goes b/ the 7/16ths rod/ screw and the 1/2" hole, works very well. All I need to do now ismake some spacers. Power Steering issues - Crawdad - 07-22-2011 Today is my day off so I installed the pulley on the pump. Wasn't too bad with the right tools. Next bolted the bracket to the pump. With a lil bit of time and sweat I was able to bolt all the brackets up. The PS pulley and crank pulley lined up good, just gotta get a smaller v-belt. Power Steering issues - firefighter2134 - 07-22-2011 so when do we get to see this beast on the road? Or TRAIL?? Great progress keep it up |
