C- Wedge bushings - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Tech (https://cb4x4.com/forum-40.html) +--- Thread: C- Wedge bushings (/thread-3808.html) |
C- Wedge bushings - snipes243 - 08-13-2015 cratchhe:cratchhe: chuzie Wrote:If it worked so well Matt, why did you have to do it many times????????? Wow chuzie Wow C- Wedge bushings - broncomatt - 08-13-2015 obviously they weren't all mine!! Since you bring it up I want to QC your wiring workcratchhe: Clay if your tires have sat or not been balanced in a while its worth having that done. An alignment is a good starting point before doing much else. chuzie Wrote:If it worked so well Matt, why did you have to do it many times????????? C- Wedge bushings - chuzie - 08-13-2015 U cant QC what you can't see! :O Sent from my GS3 on Cyanogenmod with the older / better version of Tapatalk! C- Wedge bushings - snipes243 - 08-13-2015 chuzie Wrote:U cant QC what you can't see! :O Is that because it's hidden under the rats nest? C- Wedge bushings - snipes243 - 08-13-2015 broncomatt Wrote:obviously they weren't all mine!! Since you bring it up I want to QC your wiring workcratchhe: I have balance beads I need to throw in them. C- Wedge bushings - chuzie - 08-14-2015 Balance beads could exacerbate an already unstable setup. Sent from my GS3 on Cyanogenmod with the older / better version of Tapatalk! |
