Chuzie's '77 Project - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Tech (https://cb4x4.com/forum-40.html) +--- Thread: Chuzie's '77 Project (/thread-659.html) |
Chuzie's '77 Project - chuzie - 06-17-2008 Xfer case is split from tranny and bellhousing is removed. I think I will give my rebuilder the courtesy of a somewhat clean tranny to work with so tomorrow I will scrub it down as best I can and likely drop it off on Thursday. Chuzie's '77 Project - chuzie - 06-24-2008 Well looks like I am going to be rebuilding my C4 on my own. Can't find anyone to do it for less than $600 :crying: I guess I will drop the $150 on a good performance rebuild kit, $20 on the Hayned book, and go to town on it in my spare time. So instead of a 2-3 day rebuild I am looking at a 2-3 month rebuild. What a croc. I will keep posting the progress. Chuzie's '77 Project - blazinchuck - 06-24-2008 why not buy the kit...then get joey to build it for the $300 as he said...atleast thats quicker and cheaper than a serious messup on your part. Not that you cant do it, but you and I have never done anything like this before. Check with bucketobolts...he has rebuilt a few C4's...maybe he has some great advice!! Chuzie's '77 Project - johnpaulgolf - 06-24-2008 OUCH!!!$600 Come on get wrenching!!! Chuzie's '77 Project - chuzie - 06-24-2008 I figure if I can rebuild a million dollar jet engine for an F-15 I can certainly take on a C4. However it is not a matter of skill or ability but rather TIME. How much is my time worth, how much is it worth to have the bronco down for X amount of days? I don't know. It is hot as crap outside and I don't see how much fun I can possibly have in the heat with a Bronco with zero A/C. This may be a good opportunity to suck it up and accept the down time and save a few bucks. If I screw up it will be expensive no matter how I look at it but at least I can say I gave it a try. I just had someone offer up an AODE from a '94 Thunderrbird with 150K miles and will throw in the flywheel, driveshaft, etc for $150.00 Is that a good deal? Should I go for an AOD or stick with my C4? Chuzie's '77 Project - chuzie - 06-24-2008 Ok. Nevermind. I just answered my own question with a little research. I am not willing to make all the necessary modifications to install the AOD on my rig. By the time I pay for the mods I will exceed the $$$ I save by purchasing the tranny as a bolt on app. If anyone else is interested in this purchase let me know and I will hook you up with the guy. I think it is a pretty good deal though. Here is the list of parts I am working on getting a quote on from Transtar in Charlotte for my rebuild. Part Number/Qty/Nomenclature 26006C 1 REBUILD KIT WITH STEELS 26022BHD 1*** FRONT BAND (solid non flex type) Sub R26022B if 26022BHD is not available only if R26022B is for 65-67 relined and NOT 1964 only hard band. A26912 1 REAR SERVO PISTON 26036A 1 BUSHING, FRONT STATOR 26037 1 BUSHING, REAR STATOR 26010D 1 OIL FILTER SCREEN 36034B 1** PUMP BUSHING C-6 A26530 1 PUMP GEAR SET, C-4/C-5 26046A 1 DIRECT DRUM BUSHING 26052 2 BUSHINGS, SUN GEAR 26064 1 BUSHING, TRANSMISSION CASE 26074TA 1* METAL CLAD SEAL FOR THE ADAPTER HOUSING (DOUBLE LIP) 26160G 1 MODULATOR, C4/C5 GREEN STRIPE A26654K 1 SPRAG KIT, C-4/C-5 SPR & ROLLER KIT Chuzie's '77 Project - johnpaulgolf - 06-24-2008 blazinchuck Wrote:why not buy the kit...then get joey to build it for the $300 as he said...atleast thats quicker and cheaper than a serious messup on your part. Not that you cant do it, but you and I have never done anything like this before. Check with bucketobolts...he has rebuilt a few C4's...maybe he has some great advice!! X2 Chuzie I feel your pain bro hang in there!!!:biggthumpup: Chuzie's '77 Project - jollygrngiant - 06-26-2008 Hey Chuzie, Don't know if you've seen this, but just an idea if you don't want to spen alot of money. Saw it on craigslist Here's the link http://charleston.craigslist.org/pts/727524863.html Chuzie's '77 Project - chuzie - 07-16-2008 UPS delivered the parts from Transtar today and after I double checked to make sure ALL the parts were accounted for and correct I started the teardown. I only got a few things done tonight because I am going very slow to make sure I label all the parts and don't miss a thing. All the bolts are labeled and I have marked position on most everything I can. I got the valve body and the struts. Also pulled the servos, band adjusting bolts, modulator, etc. Just the easy outer items first. Had a couple surprise gushes of fluid to clean up but that is it. So far smooth sailing. More to come tomorrow. I get to start with the endplay measurement but only if the dial indicator I bought on ebay shows up. Otherwise I will just use my feeler gages to check. I think they are just as accurate anyway but the book calls for the dial indicator at the input shaft rather than a feeler gage at the input shell. Whatever. This ain't so bad yet. I told the wife that since she screwed me out of my river rock weekend that I am getting that transmission done by sunday. By done I mean rebuilt, not installed. Chuzie's '77 Project - mudmonkey - 07-16-2008 Represent en the ville, I love it. Call me if you need some help.. |
