my full width axle build 5/23/07->10/28/07 - blazinchuck - 01-15-2009 wow, i hate to disappoint...I have done nothing!! as a matter 'o fact...JP was the last to wrench on my junk. I was upset to find out Cage wanted over $500 for 2 axle brackets,frame brackets,and hardware!!! So now, I will have no choice but to make it work now with the crap I bought used! Dont expect any updates for a while:banghead: ![]() my full width axle build 5/23/07->10/28/07 - SC74 - 01-16-2009 blazinchuck Wrote:wow, i hate to disappoint...I have done nothing!! as a matter 'o fact...JP was the last to wrench on my junk. Chuck - I feel really bad for being a part of that deal. If I can do anything to make it right let me know. I can make the frame brackets for you and see if I can round up some hardware from work. How much were just the axle brackets? If anything, you could fill them in with weld, mark the radius, and grind it back out. Time consuming PITA work I know. my full width axle build 5/23/07->10/28/07 - broncomania - 01-16-2009 blazinchuck Wrote:well, absolutely nothing has been going on...completely lost the drive. Gonna try to get back on it this weekend.it will be worth it when you gat it back together chuck. :beer: my full width axle build 5/23/07->10/28/07 - fdezone - 01-16-2009 Bummer. That bites! Okay, nuff whining. Now lets get back to work. Easier said than done - I know. I can't bring myself to purchase anything else or perform any more work. THAT'S WHY I NEED YOU TO MOTIVATE ME CHUCK!!! LET'S GO!!! You've come so far. You can easily have her ready for some early spring runs man. Get off your arse! You have an extended weekend to get some work done. my full width axle build 5/23/07->10/28/07 - chuzie - 01-17-2009 Extended weekend? Chuck? I doubt that. The man is ALWAYS working. my full width axle build 5/23/07->10/28/07 - Bighorn - 01-19-2009 Chuck with what you have and these..... http://www.ballisticfabrication.com/Flat-bottom-radius-arm-coil-mounts_p_1184.html http://www.ballisticfabrication.com/Flat-bottom-radius-arm-mounts_p_1480.html http://www.ballisticfabrication.com/Heavy-Duty-Frame-Link-Mount_p_1511.html We could make it work. Much cheaper than Cage my full width axle build 5/23/07->10/28/07 - SC74 - 01-19-2009 Bighorn Wrote:Chuck with what you have and these..... That makes Cage look bad - ballistic has good stuff and those are very reasonable prices! I'd make sure that the arm will fit over the ballistic axle bracket. my full width axle build 5/23/07->10/28/07 - blazinchuck - 01-19-2009 wow, that does make me think??? my full width axle build 5/23/07->10/28/07 - chuzie - 01-19-2009 Think? Now let's not go too far Chuck! my full width axle build 5/23/07->10/28/07 - bucketobolts - 01-19-2009 I just bought several brackets and tabs from Ballistic just before Christmas. I could not have bought the material and made them myself for what they sell them for. |
