JohnPaul's Build - johnpaulgolf - 08-20-2009 Talked to Anthony at StoneCrusher and we decided to put the Drag link on top of the pitman arm and it looks alot better :biggthumpup: ![]() JohnPaul's Build - johnpaulgolf - 10-27-2009 Aight ... since my last update I got the WH's driveshaft put in got a new(CCOR) 31 spline spool for the 9" and put the 31 spline axles in the rear ... ![]() ![]() ![]() ![]() ![]() :popc1: :popc1: JohnPaul's Build - blazinchuck - 10-27-2009 that chit's still weak...lol JohnPaul's Build - johnpaulgolf - 10-27-2009 blazinchuck Wrote:that chit's still weak...lol We will see ... that is if your junk goes to URE ... if not I will be crawling at your house that weekend :hysterical: :thefinger: :hysterical: JohnPaul's Build - chuzie - 10-27-2009 so you have some 28 spline to sell to me? JohnPaul's Build - johnpaulgolf - 10-27-2009 chuzie Wrote:so you have some 28 spline to sell to me? Big bearng ... 76-77 ... and a spool ... you want me to bring um to URE?:biggthumpup: JohnPaul's Build - chuzie - 10-27-2009 I can use the axles. Bring em. BTW- Your axleshaft is @ chucks. If you don't get it between now and then I will make sure to bring it up. I have a feeling someone is going to need it. JohnPaul's Build - shawnboymoody - 10-27-2009 Kodak here we come!:gunshot: JohnPaul's Build - johnpaulgolf - 03-26-2010 After so many broken driveshafts I am trying a traction/anti wrap bar and a limit chain ... Also got propane from "cuz1" fantasic ... love me sum "pane" ![]() ![]() ![]() O-yeah after killin' my alt. I thought I had a bad winch so I retired the "gorilla" and bought a winch that is very familiar with my Bronco ... "god-evil"'s ... he had a ramsey winch for sale and I bought it ... has rope and a BLING azz fairlead ... O-yeah I also got new gears from "Goodole'boy" so 4.88's up from 3.50's WOW a slight difference ... hehehe That re-gear job snowballed into aLot of other stuff ... new stub shaft new brake shoes front and rear new front bearings new front driveshaft u-joint new hub and drum new brake lines up front blah blah blah ... and and and and and and and and and and and and and and JohnPaul's Build - cuz1 - 03-26-2010 JPs gone crazy---- what are those King coilovers doing on the work bench? I like what you are doing. cw |
