my full width axle build 5/23/07->10/28/07 - johnpaulgolf - 02-18-2009 chuzie Wrote:Is that JP's beard before he dyed it black? I'm the one on the far right and we took that "picher" bout 18yrs ago ... :hysterical: :thefinger: :hysterical: my full width axle build 5/23/07->10/28/07 - blazinchuck - 03-01-2009 well, its been a while since ive posted here or anywhere for that matter. My buddy Shawn came over and we started on the front axle. He got the old ram assist mount cut of and the track bar mount cut off and all smoothed down. still have to remove the old radius arm mounts. I removed the 2" body lift a week ago, got the new bushings in place and done. No more body lift at all. But, by lowering the body, i ran into a problem with the brake booster/MC...so i had to cut off the shock mounts on the upper duff tubular shock mount. I will come up with another arrangement for that. Gonna order some perches for the rear, and the bead locks to get those beautiful 42" IROKS mounted up!!!!! later,Strap my full width axle build 5/23/07->10/28/07 - SC74 - 03-01-2009 Glad to see you back at it Chuck! Has Shawn found a new bowtie to work on? my full width axle build 5/23/07->10/28/07 - blazinchuck - 03-01-2009 yes, hopefully he will pick it up soon. felt good to do some work on it. i just went back outside and in 20 mins, i was able to remove the radius arm mounts off the axle tubes...still need to grind them smooth. my full width axle build 5/23/07->10/28/07 - chuzie - 03-02-2009 Good job chuck. Get that thing done! I may be interested in the 2" blocks. sick of hitting the garage door with my 3" my full width axle build 5/23/07->10/28/07 - blazinchuck - 03-02-2009 sorry chuzie...day late bro...JP got them and swapped out his 3" for them. I need help finding a correct balancer. i need a 28oz balancer with 4 holes for seprentine system. Bighorn said I can use a 351W...just gotta find one, if not ill buy one. my full width axle build 5/23/07->10/28/07 - Mill Knob - 03-02-2009 blazinchuck Wrote:sorry chuzie...day late bro...JP got them and swapped out his 3" for them. Good luck on finding one...:rubeyes:..It took for ever for me to find the correct one for my Bronco.... my full width axle build 5/23/07->10/28/07 - Bighorn - 03-02-2009 Here's one... http://cgi.ebay.com/ebaymotors/FORD-351W-HARMONIC-BALANCER-1988-1996-NEW_W0QQcmdZViewItemQQ_trksidZp3286Q2em20Q2el1116QQitemZ140150361231QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories my full width axle build 5/23/07->10/28/07 - chuzie - 03-02-2009 darnit JP!!! Guess i'll just take the hack saw to them instead. my full width axle build 5/23/07->10/28/07 - blazinchuck - 05-16-2009 well, we finally got the wheels sandblasted and Shawn painted the wheels gloss black and the rock rings Silver...I like'um!!!! i plan to mount the 42's tomorrow~! |
