10th Annual NovRun@URE '15 **The Big One Zero**TEN** - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: Misc Club Info (https://cb4x4.com/forum-3.html) +--- Forum: Wheeling Events (https://cb4x4.com/forum-16.html) +--- Thread: 10th Annual NovRun@URE '15 **The Big One Zero**TEN** (/thread-3759.html) |
10th Annual NovRun@URE '15 **The Big One Zero**TEN** - Broncitis - 11-11-2015 I found the cause of the sag in my Bronco body today which resulted in my clutch linkage troubles.Both of the spacers which are located near the rear of the front seats for the body lift are missing. This allowed the body to sag. I can get a friend to turn me some 3 inch spacers to replace the 2 missing ones. Would any one have a single stock rubber spacer which is approximately 3/4 inch thick laying around. I'd like to find both halves for one side the upper and lower. Let me know what you have and what ya want fer it. 10th Annual NovRun@URE '15 **The Big One Zero**TEN** - wepuckett - 11-11-2015 Let me look and see if I have a partial set of body mounts, know I have a complete set maybe even 2 sets. 10th Annual NovRun@URE '15 **The Big One Zero**TEN** - wepuckett - 11-11-2015 I found a couple used body mounts with both the top and bottom, but if you have those 2 basically gone you might think about replacing all your body mounts. Let me know what you wanna do. 10th Annual NovRun@URE '15 **The Big One Zero**TEN** - Timstrk - 11-11-2015 William is right on the body mount thing. A new set isn't that much and all would be in the same condition, new or old. Not difficult to change, either. 10th Annual NovRun@URE '15 **The Big One Zero**TEN** - chuzie - 11-17-2015 So no one has a video of me coming up the right side of daniel? Sent from my GS3 on Cyanogenmod with the older / better version of Tapatalk! RE: 10th Annual NovRun@URE '15 **The Big One Zero**TEN** - Bronco Biff - 10-25-2020 So % years later........reflecting back at 10th run! what a ball! |
