66 Bronco rebuild - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Tech (https://cb4x4.com/forum-40.html) +---- Forum: Build Threads (https://cb4x4.com/forum-11.html) +---- Thread: 66 Bronco rebuild (/thread-2232.html) |
66 Bronco rebuild - Casey835 - 09-02-2012 here is some more. no need to be jealous, you been driving yours past 3 yrs. I been working on mine. Its been so long since ive driven mine I forgot how much fun it is, I just remember for some reason Ive got to get it done so I can drive it again 66 Bronco rebuild - snipes243 - 09-03-2012 Looks awesome there casey 66 Bronco rebuild - BucknEB - 09-04-2012 Dammmmnnnn!!!!! That is nice!:xyxthumbs: I dig the silver frame/ silver body combination. 66 Bronco rebuild - SC74 - 09-04-2012 and shaved door handles... slick! 66 Bronco rebuild - Casey835 - 09-04-2012 Thanks evrybody, and think you are joking bout the shaved door handles or atleast i hope you are. Now its just a matter of getting it put together. I also have a cage that still needs to be welded together, painted, and installed. Also got to figure out some bump stops so as not to eat up those tires and fenders(was think bout doing something like the mud trucks) and some type of sway bar setup(probably also like mud trucks) Its strickly going to be a driver for a while then those fenders will most likely get cut. 66 Bronco rebuild - SC74 - 09-04-2012 I was joking.. But I did have to look twice! Next time I come down there to hunt ill let you know so I can come see it. 66 Bronco rebuild - Casey835 - 09-04-2012 That would be great sc74. If I remember right, you said you had family over round 310 and 45. Thats very close as in no more than 3 or 4 miles maybe. Right now im battling lining up the doors. I had them close to right before I disassembled it for paint. Back edge of pass side door is jacked above the bed. Ive already put a shim under front body mount(1/8" wasnt enough). Imconsidering shaving the pass side floor mount to see if that will work. Any suggestions are welcome. 66 Bronco rebuild - DirtyWhiteBoy - 09-04-2012 I think it looks Great , can tell you put some time in it...DWB 66 Bronco rebuild - blazinchuck - 09-10-2012 moving this to the build threads Casey...keep us posted!!! 66 Bronco rebuild - Casey835 - 11-02-2012 Here is my new hard top. Still got to get ready for paint.[ATTACH=CONFIG]6591[/ATTACH][ATTACH=CONFIG]6592[/ATTACH][ATTACH=CONFIG]6593[/ATTACH][ATTACH=CONFIG]6594[/ATTACH][ATTACH=CONFIG]6595[/ATTACH] |
