Need help with transfer case install - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Tech (https://cb4x4.com/forum-40.html) +--- Thread: Need help with transfer case install (/thread-2285.html) |
Need help with transfer case install - chuzie - 08-18-2010 so what was the deal? why did it now want to go on before? how did you fix it? Need help with transfer case install - 73Bronc - 08-18-2010 chuzie Wrote:so what was the deal? why did it now want to go on before? how did you fix it? I used the same method as before. The difference is that the 2" body lift gave me the clearance I needed to level everything up. Before the 2" body lift, the case kept bumping the body rib and would not get level enough. I love it when a plan comes together. Now, on to the floor shifter install! :beer: :toothy12: Need help with transfer case install - JayT - 08-18-2010 Congrats! :chili: Need help with transfer case install - blazinchuck - 08-18-2010 body lifts???? who needs that? just cut the sh*t out of the floor and you'll shove a 435 and a 205 right in there...rolmao:hysterical: good job!:xyxthumbs: Need help with transfer case install - 73Bronc - 08-18-2010 blazinchuck Wrote:body lifts???? who needs that? just cut the sh*t out of the floor and you'll shove a 435 and a 205 right in there...rolmao:hysterical: :notworthy: :eyecrazy: :hysterical: |
