Cam advice.... - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Tech (https://cb4x4.com/forum-40.html) +--- Thread: Cam advice.... (/thread-2609.html) |
Cam advice.... - bucketobolts - 02-01-2011 I was not sure which Trick Flow heads your running, so I used the High Port flow #'s with 2.02/1.80 valves. If your running a different set up I can modify it with no problems. But that combo seems to be a pretty good one. Looks like it makes just under 400HP and almost 400FtLbs of torque from 3-5K. ![]() Cam advice.... - blazinchuck - 02-01-2011 wow, thats not bad...ill see if i can get the actual list of parts, maybe you wouldnt mind doing one more for me when i get the info? Thanks Aaron!!!!! Cam advice.... - blazinchuck - 02-01-2011 heres a quick run down, just talked to Jeff(PO) '95 truck block true roller stock crank(balanced and polished) stock rods w/ARP bolts trick flow roller cam/roller lifters Crane 1.6 roller rockers performer RPM alum intake Probe forged domed pistons w/ plasma moly rings block bored .30 over plus .01 over for NOS trick flow twisted street head 2.02/1.60 ARP head studs TCI torque converter 1000rpm stall over stock |
