am i crazy? - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Talk (https://cb4x4.com/forum-39.html) +--- Thread: am i crazy? (/thread-2647.html) |
am i crazy? - chuzie - 02-02-2011 So much for stepping back and giving it some thought. am i crazy? - blazinchuck - 02-02-2011 keep in mind, this is something ive always dreamed of having. i still remember seeing the Odd Rod in the parking lot of Lowes Motor Speedway back when I had a K5 I wheeled. I was floored then...and im still crazy bout them.Ive been folowwing all the lowered build threads on classic since they started. This is what I want, I wont give up wheeling either, but it will be on a lower level than where im at now am i crazy? - broncosbybart - 02-02-2011 josephitguy Wrote:You have that backwards, at 40 he has trouble getting into FBG and the Dodge he needs a low car to get his old self into the CAR, my mom cant get in anything I have. Just saying. this past weekend at the gulches he was mentioning things about handicapped accessible trail rigs. perhaps you are onto something... dibs on the axles/tires/wheels- just kidding. what are you thinking of doing chuck??? am i crazy? - josephitguy - 02-02-2011 If you kept the engine tame it could be a great daily driver, OD trans with 302 with a light chassis would yield > 16 MPG. Air bags to slam it when parked and a soft ride, not a bad I idea. am i crazy? - firefighter2134 - 02-02-2011 Wow how dod I miss this one? Its all in what makes u happy am i crazy? - ncsubronc - 02-02-2011 did anyone see the 1971 Bronco-based 2wd postal van in the back of the Bronco Driver Issue # 46? i thought that might make a good platform for a lowered bronco since it was set up for 2wd already and apparrently shares the same frame? i got the picture scanned of the ad...i'll see if i can get it loaded.. am i crazy? - firefighter2134 - 02-02-2011 actually found these pics of one for sale earlier. but i wouldnt throw gasoline on a fire...:hysterical: am i crazy? - 744x4 - 02-02-2011 [ATTACH]:biggthumpup:[/ATTACH] am i crazy? - 744x4 - 02-02-2011 You will end up sectioning and channeling the Body to get it that Low but it is Doable.A T-Bird like Mine has IRS that would be easier to adapt and just add a Mustang 2 ft end and call it done.A T-Bird is alot cheaper than using Cobra parts for IRS and you could run the Whole T-Bird Ft end also if so inclined as they are Very simple and came with a 5.0 or a Supercharged V-6. am i crazy? - blazinchuck - 02-02-2011 nah, i can use drop spindles...but im not sure i want it that low yet... |
