Irmo73's Build - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Tech (https://cb4x4.com/forum-40.html) +--- Thread: Irmo73's Build (/thread-3017.html) |
Irmo73's Build - Irmo73 - 12-20-2011 Dallas convinced me to go with them since he has dealt used them for his GM trucks the only delay was that they initially sent a large case alternator which wouldnt fit. internal regulator internal fan looks like its running while im idling at about 800rpm dont know if it has one of those internal triggers havent dropped below 14 volts at idle or seen any dimming etc (nice to actually have a voltmeter) of course ive only had it one day did i mention i also have a new wiring harness? Irmo73's Build - Crawdad - 12-20-2011 Who is this Dallas?!!!! Is this your mechanic that has been doing all the work? I'm surprised you couldn't use your volt meter on ur new cluster guage. Irmo73's Build - Irmo73 - 12-20-2011 I meant that my old cluster's ammeter didnt work so I never have had any readings until the new cluster's voltmeter Dallas Ebel is a good old truck mechanic with a autoshop here in Irmo. He has done mainly GMs but now has a hired on a Ford guy (Brian). They know oceans more than I do, lol!! Im smart enough to know I only know enough to be dangerous... Irmo73's Build - Crawdad - 12-21-2011 Irmo73 Wrote:Im smart enough to know I only know enough to be dangerous... Me and several others on here can say the samething! I'm a Jack-of-all trades, but Master-of-none-of'em! I will find this Dallas you speak of. Do you know if he does wheel alignments? Irmo73's Build - Irmo73 - 12-21-2011 Not sure but probably Irmo73's Build - Irmo73 - 01-03-2012 rear axle work started yesterday 31 spline axle rear discs trutrac bit the bullet over the holidays and ordered a wild horses hydroboost figured i do enough in town stopping and starting Irmo73's Build - broncosbybart - 01-03-2012 Nice!! Irmo73's Build - Irmo73 - 01-03-2012 Thanks!! Now if only it would all go in ok Irmo73's Build - blazinchuck - 01-03-2012 thats gonna be sweet upgrade!!! looking sharp Irmo73's Build - Irmo73 - 01-06-2012 just had my first case of what i think was death wobble hit a relatively benign bump in the road at about 50mph and it felt like the front end was going to come off for about 2 secs!! after that it was totally fine and has not happened since the stock radius arms look worn out in several spots |
