306 EFI build - blazinchuck - 12-30-2011 also, when i 1st did my efi swap...i had to lose my schrader valve. so a while back...i found a tbird with the fuel connectors and pressure valve on the pass side like what i have. any problems if i go with this for this 306? is it better or worst than the mustang HO fuel rail? injectors: the guy that i got the gt40 intake from gave me 2 sets of 19lb injectors. doesnt look like any of them have been rebuilt, but there was a bcbroncos with what looks like the upper/lower o-rings for injectors(can anyone confirm this) should i do anything with these injectors? pop test? rebuild? or use what im using right now with the 5.0? and in one of the pics...you can see a small crack in the line. this is the front cross-over fuel rail line. it looks like a grey protective jacket...yall think this is ok? i dont see any damage under it at all. thanks again guys 306 EFI build - broncosbybart - 12-30-2011 yeah, a 97 would have had the non-P heads. Balancer would be the 3 bolt type. I have robbed one off of a 97 before. Not sure if you've gone to the 90 degree thermostat housing yet. You'll need it. You did a good job cleaning that engine up. Keep it up and I'll send a few your way ![]() 306 EFI build - blazinchuck - 12-30-2011 ayone got thoughts on the intake hitting the valve cover?? i dont want to buy a spacer. i want to cut or remove that pressed in 90 and maybe thread it for a plug??? never tried to pull one of these out 306 EFI build - broncosbybart - 12-30-2011 heck, i think it wouldn't be hard at all to remove the fitting and tap it. I'd use a pipe thread on it. While you are at it, I'd tap the lower intake (for the EGR port) and plug it off, like I did on my build thread. 306 EFI build - blazinchuck - 12-30-2011 broncosbybart Wrote:heck, i think it wouldn't be hard at all to remove the fitting and tap it. I'd use a pipe thread on it. While you are at it, I'd tap the lower intake (for the EGR port) and plug it off, like I did on my build thread. can you show me what youre talking bout? thx 306 EFI build - SC74 - 12-30-2011 Yes, those are the injector o-rings. I would soak the injectors in some sea foam for a night and then do a pop test on them. 306 EFI build - bucketobolts - 12-31-2011 If you need to upgrade I have several sets of 24 lbs injectors I can swap for something. The fuel rails look like they should work. I don't think you need to up grade them to billet logs...yet:bdent: The Trick Flow set up works very well with fuel injection. Their stuff even allows for further mods down the road if needed. If I remember correctly, the engine Carl W. ran in his Bronco had a TFS head/cam combo... [YOUTUBE]0SDUFp7kqK4&list[/YOUTUBE] Can't get the flippin' link to embed ![]() i edited it Aaron...its kinda a pain 306 EFI build - chuzie - 12-31-2011 I believe that stuff is cast aluminum so keep in mind if you screw it up you will be going to the junk yard for a replacement 306 EFI build - chuzie - 12-31-2011 broncosbybart Wrote:yeah, a 97 would have had the non-P heads. Balancer would be the 3 bolt type. I have robbed one off of a 97 before. The years of the non-P head was 96-97.5 so some of the 97 will have the dreaded P heads. 306 EFI build - chuzie - 12-31-2011 blazinchuck Wrote:also, when i 1st did my efi swap...i had to lose my schrader valve. so a while back...i found a tbird with the fuel connectors and pressure valve on the pass side like what i have. ................ |
