Broncitis Rat Rod build thread. - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Tech (https://cb4x4.com/forum-40.html) +--- Thread: Broncitis Rat Rod build thread. (/thread-3843.html) |
Broncitis Rat Rod build thread. - chuzie - 09-06-2015 It really depends on how bad it is. Obviously the extremely deteriorating stuff will not provide continuity to ground. Sent from my GS3 on Cyanogenmod with the older / better version of Tapatalk! Broncitis Rat Rod build thread. - Broncitis - 09-06-2015 Well the rain has put a stop to my floor repairs at this time. Thats OK tho we need the rain and I just thru a 50 lb bag of pasture rye grass seed out around my deer stands in SC today. This rain should germinate it. Broncitis Rat Rod build thread. - Broncitis - 09-06-2015 Got all the 11 ga. panels cut and welded on the drivers side and the 16 ga. cut and fitted. Still have a 2 in. x 10 in. piece to cut an then weld the 16 up and the rear section will be patched. I am sure you guys know how mean humidity is, well it plum whips me. I used to work 12 hour shifts at the saw mill mostly welding and heavy maintenance. Couldn't do that any more. If I did they'd have to bury me or run me thru the chipper. I'll see what I can get done tomorrow. Hope to finish the floors. Broncitis Rat Rod build thread. - Broncitis - 09-07-2015 I got the drivers side welded out this morning. Now on to the front portion of the passenger side floor. Broncitis Rat Rod build thread. - broncosbybart - 09-07-2015 I think you're to too tough to be run through a chipper. Sounds like you've about got it done. Broncitis Rat Rod build thread. - chuzie - 09-07-2015 I would feel bad for the chipper. Sent from my GS3 on Cyanogenmod with the older / better version of Tapatalk! Broncitis Rat Rod build thread. - Broncitis - 09-07-2015 chuzie Wrote:I would feel bad for the chipper.Its according to how fresh the blades and anvil are on that chipper. LOL. Heres what I cut out of passenger floor a few minutes ago. ![]() Sent from my NEC-NE-201A1A using Tapatalk Broncitis Rat Rod build thread. - Broncitis - 09-07-2015 The floors have been patched and painted. The front portions will have to wait for cooler weather. ![]() Sent from my NEC-NE-201A1A using Tapatalk Broncitis Rat Rod build thread. - Broncitis - 09-07-2015 I got the mount and sliders put in and the drivers seat bolted in. The bolts needed to mount the seat to the sliders needs to have a thin head in order to allow the slider to move to its limit fore and aft. Can someone tell me what those bolts are called. Sent from my NEC-NE-201A1A using Tapatalk Broncitis Rat Rod build thread. - broncosbybart - 09-07-2015 Not sure on bolts. On nuts they do a jam nut that is thinner. I would probably use a button head allen head type bolt. They are pretty low profile. |
