Any Thoughts on these Axles? - Printable Version
+--- Thread: Any Thoughts on these Axles? (/thread-3923.html)
Pages: 1 2 3 4
Any Thoughts on these Axles? - Bronco Biff - 05-08-2016
Happy Birthday!!!
Any Thoughts on these Axles? - Broncitis - 05-08-2016
Thanks for the Birthday Day wishs everyone. I ran away from the Rest Home Chuzie. Hehehe... Brought the 435 and Adapter home today. Anyone needing a T shift style transfer case let me know. I have a couple/
Any Thoughts on these Axles? - jdowns67 - 05-29-2016
OK, don't laugh at me bringing this up but... have you guys ever heard of using a product like Loctite 638 instead of tack welding the caps on the u-joints. We use this at work for certain applications and it works great. I just can't help but think that tack welding the caps could damage the cap/bearing surfaces in some way. http://na.henkel-adhesives.com/industrial/product-search-1554.htm?nodeid=8797714153473
Any Thoughts on these Axles? - chuzie - 05-29-2016
Low heat. Just enough for slight penetration so it won't spin. Not hot enough to damage anything inside.
That being said, I have to be able to remove joint without destroying it. Just grind the tack and done. I wonder how using loctite would go when it comes time to disassemble.
Mild heating with propane torch breaks it down. I think above 350 degrees. It's basically a similar formula as loctite thread locker. Just tweaked for strength and clearance. We also use other formulations like 603 and 680
Hmmm. I like that. I will give it a try next time and see how it goes.
