my full width axle build 5/23/07->10/28/07 - blazinchuck - 10-26-2009 chuzie Wrote:VSS fix- Dill ouy VSS w/ 7/16 bit. Piggy back stock cable (gear removed) onto VSS. Use 1/4x 3-1/5" bolt + some type of spacer to support the two mounts. Will mount directly into XFER case. Works like a dream. Good idea Chuck. thats awesome! thanks for checkin on that MAF..ill get the right one. my full width axle build 5/23/07->10/28/07 - SC74 - 10-26-2009 blazinchuck Wrote:we are going to install the battery right behiond the Pass side headlight. thanks guys! That's where I thought mine would go too, but we didn't have enough room to fit a headlight, battery, and stuff a tire. We narrowed our grills basically the same, but you stretched your fenders and I shortened my hood - that couple inches must make the difference. I really like your air box setup too - ya'll keep up the good work :xyxthumbs: my full width axle build 5/23/07->10/28/07 - blazinchuck - 10-31-2009 well, just the keep the thread current...started running the fuel lines and wiring Fri night. Chuzie came by and we were at the point to fire the motor up, but the motor wouldnt turn. it was bound up! so this morning i began removing the trans...still the motor wouldnt turn. so i took the bell housing off and BINGO! the motor turns, so i found the pressure plate scrapping the bell housing. i ground the housing and some off the bolt areas on the pressure plate...everything turns good now. a buddy came by to help install the tranny. Sunday comes...she will run! ill keep yall posted my full width axle build 5/23/07->10/28/07 - chuzie - 11-01-2009 EXCELLENT! You better not fire that damn thing up until I get there!!! We are going to wake the neighbors up tomorrow!!! I think, after tomorrow, your rig will be on the down hill slope (no pun intended) of this battle to make URE. Way to stay focused and keep on the engine/tranny issue today. I would have had to walk away for a day or two over that one. my full width axle build 5/23/07->10/28/07 - kwiksilver - 11-01-2009 I got the bender all warmed up for next weekend. Lookin forward to getting that thing caged up! We are stiil a go right? I heard a tale of you letting Marc do it??? my full width axle build 5/23/07->10/28/07 - JayT - 11-01-2009 Hell yeah! glad to hear that!!! One more wrenchin weekend left before the trip! my full width axle build 5/23/07->10/28/07 - SC74 - 11-01-2009 Sounds great Chuck - glad you got the motor issue figured out, but it sounds like it was a PITA getting to it. Do you have the driveshafts made? What else do you lack besides tube work? Keep up the hard work and we all expect some youtube footage of the motor running :popc1: my full width axle build 5/23/07->10/28/07 - blazinchuck - 11-01-2009 kwiksilver Wrote:I got the bender all warmed up for next weekend. Lookin forward to getting that thing caged up! We are stiil a go right? I heard a tale of you letting Marc do it??? hahahaha....as if. you are the king for a reason are you not?:notworthy: my full width axle build 5/23/07->10/28/07 - broncomania - 11-01-2009 great news chuck. i hope you get it fired up today buddy. i know youve had problems but you are doing it right. in my opinion you will have one of the baddest broncos around hands down. my full width axle build 5/23/07->10/28/07 - blazinchuck - 11-01-2009 broncomania Wrote:great news chuck. i hope you get it fired up today buddy. i know youve had problems but you are doing it right. in my opinion you will have one of the baddest broncos around hands down. thank you Mike...as of today...(The Motor Was A Good Deal!):xyxthumbs: [SIZE="7"]IT RUNS!![/SIZE] |
