what have you wrenched on your bronco(s) today? - snipes243 - 09-17-2013 Well the string holding the tailgate was annoying And the fenders were for clearance Sent from my iPhone using Tapatalk - now Free what have you wrenched on your bronco(s) today? - chuzie - 09-18-2013 Replaced turn signal switch and wiring. Replaced cruise control controller. Rewired winch with 3/0 cables and replaced all solenoids. Replaced master cylinder. Jury still out on explorer brakes. Headed to junkyard now to snag a gt40 upper to go with my newly acquired lighting lower intake. Sent from my SAMSUNG-S3 using Tapatalk 2 on CyanogenMod what have you wrenched on your bronco(s) today? - 1st Bronco - 09-18-2013 broncosbybart Wrote:What are you trying to do? If it is the front axle spindles, a regular heavy hammer and a block of wood work great. You just need to alternate where you hit the spindle. It won't go if you keep hitting it in the same spot. Make sense? Took your advice and it's off. Thanks. what have you wrenched on your bronco(s) today? - broncosbybart - 09-18-2013 Cool! what have you wrenched on your bronco(s) today? - snipes243 - 09-21-2013 Set up the third member this evening ![]() ![]() Sent from my iPhone using Tapatalk - now Free what have you wrenched on your bronco(s) today? - Jbass - 09-22-2013 Finally a stock hood to replace my fiberglass! what have you wrenched on your bronco(s) today? - chuzie - 09-26-2013 Installed and painted another hood. Sealed windshield frame. Installed limiting straps for hood. Installed explorer 65mm tb Sent from my SAMSUNG-S3 using Tapatalk 2 on CyanogenMod what have you wrenched on your bronco(s) today? - jac77 - 09-26-2013 straps for hood sounds like a good idea or you just can remember to put the pins back in the hood before you drive down the road. Haha just kidding does sound like a good idea. But I've been told not to add anything to the list before the nov run. what have you wrenched on your bronco(s) today? - chuzie - 09-26-2013 Haha. You've been cut off! This time i left hood up in garage and started bronco from under hood while in drive. Garage crunched hood, hood crunched windshield and bronco hit two hondas in driveway. Sent from my SAMSUNG-S3 using Tapatalk 2 on CyanogenMod what have you wrenched on your bronco(s) today? - jac77 - 09-26-2013 Dang |
