what have you wrenched on your bronco(s) today? - blazinchuck - 10-07-2013 Got a few things done...soft upper Windows on half doors Sent using my HTC ONE via Tapatalk what have you wrenched on your bronco(s) today? - cuz1 - 10-07-2013 Very cool what have you wrenched on your bronco(s) today? - chuzie - 10-07-2013 Do they seal well? Sent from my SAMSUNG-S3 using Tapatalk 2 on CyanogenMod what have you wrenched on your bronco(s) today? - blazinchuck - 10-07-2013 considering i dont have any weather stripping on the upper or lower body/top...i think it does pretty good. once i get the seals...should be a nice snug fit. pretty ridged what have you wrenched on your bronco(s) today? - blazinchuck - 10-14-2013 Got to work on my doors today. Cut out the rust holes on the outside panel...still need to make repairs to the inside of doors, but not messing with that til after NovRun. They work great. Been windy today...really like them Sent using my HTC ONE via Tapatalk now Free what have you wrenched on your bronco(s) today? - chuzie - 10-14-2013 while chuckles played with his cute little doors, i: Fixed tommy's erratic idle. Bad pip sensor. Replaced dizzy assy. Fixed tommy's brake light switch that was shorting on pedal support and blowing fuses. Modified 70mm maf housing for douggie boy. Sent from my SAMSUNG-S3 using Tapatalk 2 on CyanogenMod what have you wrenched on your bronco(s) today? - broncosbybart - 10-14-2013 Bronco looks awesome, Chuck! I'll compare notes at the Nov run. Now if we could only get you to paint it. Got a little wiring done on Skip's old Bronco. Chuzie would be disappointed as I went about removing wiring... There was a pile of it under the dash. Here are a few pieces that I removed from the ignition system under the hood. Also removed the front bumper to clean it up and repaint. what have you wrenched on your bronco(s) today? - dixieboyz13 - 10-14-2013 is that an extra brake booster i see on the floor? also, where did the winch bumper come from? what have you wrenched on your bronco(s) today? - snipes243 - 10-15-2013 Pumping the fuel system to day. Made a little t fitting to plump my -8 return line into the stock filler neck ![]() Sent from my iPhone using Tapatalk - now Free what have you wrenched on your bronco(s) today? - chuzie - 10-15-2013 Crafty little bastard. Nice work. How do you "plump" something? ;-) Sent from my SAMSUNG-S3 using Tapatalk 2 on CyanogenMod |
