my full width axle build 5/23/07->10/28/07 - blazinchuck - 11-20-2009 alright, drove the bronco last night...it did great. so i decided to drive it to work, what a rush...to finally drive her again!! my full width axle build 5/23/07->10/28/07 - SC74 - 11-20-2009 WOW - driving it to work on 42's!!!! [SIZE="5"]ROLLIN ROLLIN ROLLIN[/SIZE] my full width axle build 5/23/07->10/28/07 - JayT - 11-20-2009 Right?! Incredible to have a rig that good on the trail, and still streetable... Gotta love that fat bottom girl! my full width axle build 5/23/07->10/28/07 - blazinchuck - 04-16-2010 alright, got some "much needed work" done before riverrock tomorrow. fixed a bunch of steering issues...clocked all the heims on the drag link and tie rod, so they wont rotate when turning.changed the oil pan gasket. retro fitted the AC compressor to on board air! I took some pics, just need to upload from the phone. works great, just havent got the tanks installed yet...but it pumps the tires up awesome! I have the camper loaded in the dodge and the trailer loaded with the bronco and gear. looking forward to hitting riverrock! havent been since FSB's went there almost 2 yrs ago. well, im off to bed...getting up at 4:45am!!!!!! my full width axle build 5/23/07->10/28/07 - blazinchuck - 05-15-2010 just removed the tranny, tcase, and exhaust. time to replace seals, gaskets, and get some paint on this stuff. i might remove the motor, i still need to fix the oil pan leak and it too needs some paint. my full width axle build 5/23/07->10/28/07 - godevil - 05-15-2010 Glad you found some motivation, lend me some. my full width axle build 5/23/07->10/28/07 - blazinchuck - 06-15-2010 btt...gonna try to get this finished for a gulches trip in 2 weeks. dayum, ive been slack my full width axle build 5/23/07->10/28/07 - chuzie - 06-15-2010 NO COMMENT!!! my full width axle build 5/23/07->10/28/07 - blazinchuck - 08-11-2010 went out and got a little work done. got both the rear calipers replaced w/new pads...bled the brakes(rear) and took it for a drive...i feel like the motor is putting down way more power(stupid brakes have been dragging for a long time!!)...now just before i got back home the pedal was getting softer and softer...so i guess ill re-bleed all the brakes, i think i might have ran low on fluid since bleeding the rear...im not worried, but ill fix it tomorrow. my full width axle build 5/23/07->10/28/07 - chuzie - 08-12-2010 and you thought the efi was a mistake. silly rabbit |
