File Line Function
/printthread.php 287 eval
what have you wrenched on your bronco(s) today? - Printable Version
+--- Thread: what have you wrenched on your bronco(s) today? (/thread-2701.html)
what have you wrenched on your bronco(s) today? - scbronco - 01-21-2014
well, I didn't do it today, but over the weekend, I replaced the clutch, main fuel line, adjusted the carb and choke, and fixed my fuel guage issues (sort-of). the fuel guage needs a good switch, but right now I have the auxiliary tank hard wired to the guage and working. this basically means I run the main tank empty with no guage, and then when I switch to the front tank the guage measures as advertised. a new switch will fix the problem right.
I took her out to the only hill in sumter on MLK day, and climbed it no problem. carb still gives some issues going nose down, but its much better than it was. still want efi, maybe after taxes...
anyway, there it is...
what have you wrenched on your bronco(s) today? - Crawdad - 01-21-2014
Hill + Sick Pony = good pics! right?!! Let's see them! Will you be around this Friday?
what have you wrenched on your bronco(s) today? - chuzie - 01-26-2014
Sorted a million nuts, bolts, washers, and misc bronco bits from my 5gal left overs bucket. Ugh. Took forever!
Sent from my GS3 on CyanogenMod with tapatalk2
Oh, mounted my hi-lift jack on rear tire swing. Gas can next.
[Image: y3ujahu3.jpg]
what have you wrenched on your bronco(s) today? - blazinchuck - 01-26-2014
looks good...is that the best ya can do ? lol
Well considering the shitty foundation upon which i have to work, i think i managed just fine. Just rotated the eyelet 90 which allowed me to move jack 4" right. Hugs tire circumference better now
what have you wrenched on your bronco(s) today? - broncosbybart - 01-26-2014
I don't like it. The jack needs to go more toward the right. What is the point of putting a high lift back there, if it doesn't stick out far enough to get snagged on something?
And no, I don't want to hear what temp it is down there right now. It's probably a balmy 40 degrees here. I do like that big wall mounted fan though.
Hey, there is only enough room for one smart ass on this forum pal!
what have you wrenched on your bronco(s) today? - jac77 - 01-26-2014
Started working on the back bumper swing out,it's going to have gas,water can and a cooler.
(For when Chuzie runs out of gas or gets to hot)
Hmmmm how much should a bumper swing out weigh?? Haha
what have you wrenched on your bronco(s) today? - chuzie - 01-28-2014
Fabbed holder and added gas can. Still pondering on locking mechanism.
Installed swing arm pivot lock.
[Image: papydutu.jpg]
[Image: aty9yra5.jpg]
