what have you wrenched on your bronco(s) today? - snipes243 - 01-28-2014 Only one gas can. You should add another just to be safe Sent from my iPhone using Tapatalk what have you wrenched on your bronco(s) today? - chuzie - 01-28-2014 Ur a dick Sent from my GS3 on CyanogenMod with tapatalk2 what have you wrenched on your bronco(s) today? - chuzie - 01-30-2014 Pulled all 4 tires, removed beadlocks, vacuumed all balancing beads, installed beadlocks, retorqued 200 bolts in 3 increments, installed tires. They are getting rebalanced tomorrow. Fun factor: -9 ugh! Sent from my GS3 on CyanogenMod with tapatalk2 what have you wrenched on your bronco(s) today? - broncosbybart - 01-30-2014 Guess the balancing beads not work out? How much weight did you have in each tire? what have you wrenched on your bronco(s) today? - chuzie - 01-30-2014 They will go back in. My weights got ripped off over the last few trips and it is too much for beads to compensate. About 8oz in each. I like to initially balance with weights and let beads do the long term dynamic balancing as tires wear. Sent from my GS3 on CyanogenMod with tapatalk2 what have you wrenched on your bronco(s) today? - broncosbybart - 01-31-2014 snipes243 Wrote:Only one gas can. You should add another just to be safe ^^^^^^ oh, and what he said ![]() If you could add a pickup in the bottom of the can and hook it to a fuel selector, that'd be sweet! no need to get out of the truck... what have you wrenched on your bronco(s) today? - chuzie - 01-31-2014 Need i remind you who ran out of gas on the trails during the last work day bart? Sent from my GS3 on CyanogenMod with tapatalk2 what have you wrenched on your bronco(s) today? - chuzie - 01-31-2014 Fwiw- i have never run out of gas. It has always been either my system vapor locking or my stupid pickup starving at extreme angles. I am confident i fixed the vapor lock issue by removing the return line routing through the accumulator. One day i would like to run an in tank pump or the walbro pickups to fix the other half of the problem. Until then, i still run the risk of starvation at extreme angles but i will never run out of gas! Sent from my GS3 on CyanogenMod with tapatalk2 what have you wrenched on your bronco(s) today? - 1st Bronco - 02-03-2014 [ATTACH=CONFIG]7527[/ATTACH] before picture. [ATTACH=CONFIG]7528[/ATTACH] after picture. Front tow hitch and steering stabilizer installed thanks to a more skillful friend. Next, remove ugly NC4x4 sticker and find some 31 A/T tires..... Hitch is bolted, three #8 on each side, not welded, per CB4x4 instructions. what have you wrenched on your bronco(s) today? - blazinchuck - 02-03-2014 very nice, are you planning to build a bumper or use a stocker? |
