mini buildup - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Tech (https://cb4x4.com/forum-40.html) +---- Forum: Build Threads (https://cb4x4.com/forum-11.html) +---- Thread: mini buildup (/thread-1311.html) |
mini buildup - snipes243 - 11-04-2012 Thanks man Now just gotta get the new dash in, and the rear axle housing. Then if time allows my new fox 2.0 shocks mini buildup - chuzie - 11-04-2012 I looked at the Fox shocks as an option for the setup on my rear axle. The adjustability would have be awesome but they did not offer something with the measurement range I required. ![]() mini buildup - snipes243 - 11-04-2012 Yeah I got a pair of 2.0 emulsions with external res. for cheap so we will see mini buildup - snipes243 - 05-03-2014 I figure I would update this thread since replacing my clutch turned into another drivetrain rebuild. I got all the old drivetrain out. ![]() Now that its all not going back in I decided to change my rear main seal out since it was leaking. ![]() ![]() Ended up not being to bad had to take the drag link and track bar out to drop the pan. I did rip one seal on the first time but I had an extra, put back together with no problems just took a bit of time. Now I'm waiting for the oil pan gasket to come in. It took a couple trips but we firguired out the right one. The block came out of 74 galxiee. Sent from my iPhone using Tapatalk mini buildup - chuzie - 05-03-2014 I hope you RTV'd the piss out of that seal. Sent from my GS3 on CyanogenMod with tapatalk2 mini buildup - snipes243 - 05-03-2014 I offset the seal put rtv on the ends, and sprayed a light coat of copper gasket on the mating surfaces. There was little rtv on the one I took it probbally didn't need to be replaced but I didn't anyway Sent from my iPhone using Tapatalk mini buildup - snipes243 - 06-26-2014 Upgraded the arb air line to there heavy duty air line. ![]() ![]() I went ahead an installed a air hose for my compressor ![]() Sent from my iPhone using Tapatalk mini buildup - chuzie - 07-02-2014 How far did the atlas shift your drive shafts? Whatcha gonna do with old ones? mini buildup - snipes243 - 01-18-2015 Well today I installed a set of 4.5 coils to try out. Also installed a set of hd coil buckets. Now the limiting factor is the shocks ![]() ![]() Sent from my iPhone using Tapatalk mini buildup - chuzie - 01-18-2015 Shocks are optional. Trash 'em Sent from my GS3 on Cyanogenmod with the older / better version of Tapatalk! |
