ParadisePWoffrd's EB - broncosbybart - 09-25-2011 you've come a long way with that thing! you gonna try and come out to URE for our Nov run? i'd love to see it in action. ParadisePWoffrd's EB - ParadisePWoffrD - 09-26-2011 thanks for the comments guys... I will try to make it to URE... not sure what Nov has in store for me yet... also depends if I can get the 60 in or if the 44 survives a few rides in October... ParadisePWoffrd's EB - ParadisePWoffrD - 10-08-2011 went out and found I had no brakes thanks to the hose between master and distribution block... Took the chance to upgrade to rear discs with adjustable proportioning valve... For future reference I used: - 91 Sidekick rotors (dont have to turn down shaft) - GM Metric Caliper - weld on caliper bracket... could have used bolt on instead... If anyone knows of a good bolt-in manual master to upgrade to, Im interested... ParadisePWoffrd's EB - blazinchuck - 10-08-2011 i ran manual disc using the f250 MC bigger bore/stroke...however, since your 4 wheel disc..you'll probably need. equal size front and rear reservoir . i think a corvette MC might work...dont know yrs tho ParadisePWoffrd's EB - ParadisePWoffrD - 10-31-2011 got to wheel a little this weekend. It did the few things I asked it to do, and being slick kept the front end together... I realized 2 things in the short while: - Need to install an electric fan (and repair my alum rad) - Need a bigger master for quicker brakes ParadisePWoffrd's EB - ParadisePWoffrD - 11-14-2011 Saturday I installed a new radiator and elec fan... Had to do a little clearencing to the core support to mount it as a pusher (it wouldnt clear as a puller) I really need to get some tube work done on the front end to clean all this up.. ParadisePWoffrd's EB - ParadisePWoffrD - 11-14-2011 Tonight i installed the best upgrade yet.... yup, some tunes... ParadisePWoffrd's EB - ParadisePWoffrD - 11-29-2011 got the new radiator and electric fan installed, along with a new core support... have to rework the front clip and winch mount too now to compensate... ill get some pics up later ParadisePWoffrd's EB - blazinchuck - 11-29-2011 good dal, cant wait to see the new install pics!! tunes are always good to have lol ParadisePWoffrd's EB - ParadisePWoffrD - 12-01-2011 Here are some pics of it. New radiator mount & brackets holding up front clip. The electric fan is under the tube as it wouldn't fit as a puller. The h4 headlights hit the tube so I replaced them w/ some old hellas I had around. Also you can see how its farther forward now. So either need new winch mount or cut out grill. You can really see that's its farther here. Got a few choices: stretch fender or make new mounts. Where its at now shaves ~3" off per side. Heres the pics of the tunes. I put 12v charger with miniplug input & volume control. Also you can see the cold start plunger & rocker for the fan. |
