JP's New Front Bumper!!!! - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Talk (https://cb4x4.com/forum-39.html) +--- Thread: JP's New Front Bumper!!!! (/thread-968.html) |
JP's New Front Bumper!!!! - broncomatt - 09-03-2008 Looking good Jp, how about an extra brace/bolts. Nothing like ripping out the tips of your frame. Broncomatt JP's New Front Bumper!!!! - 744x4 - 09-04-2008 You can use the rear underside bolt holes also that are farther back in the frame but getting a nut on them sucks.Thread the bumper itself and it is easier. JP's New Front Bumper!!!! - johnpaulgolf - 09-04-2008 broncomatt Wrote:Looking good Jp, how about an extra brace/bolts. Nothing like ripping out the tips of your frame. 10-4 :biggthumpup: 744x4 Wrote:You can use the rear underside bolt holes also that are farther back in the frame but getting a nut on them sucks.Thread the bumper itself and it is easier. 10-4 I like that idea... ![]() JP's New Front Bumper!!!! - Timstrk - 09-05-2008 Mount your bumper where you want it. Drill the hole to match the hole in the bottom of the frame. Remove the bumper from the truck. Put a bolt through the hole with a nut on the inside of the mounting channel of your new, spiffy bumper. Weld the nut in place. Take the bolt out and replace the bumper into the frame. Everything will line up and just put the bolt back in and tighten. Doesn't take much of a weld to hold the nut in place but practice makes a better weld. Tim JP's New Front Bumper!!!! - broncomatt - 09-05-2008 For even more beef, I added braces that go back to the engin girdle(the brace in the frame). That will add support to the end of the frame. I used the two holes that were there. Just dug up some realy long bolts to fit. Broncomatt JP's New Front Bumper!!!! - johnpaulgolf - 12-19-2008 Just wanted to bring this back to the top...:biggthumpup: If anyone needs a bumper or any custom tubing ect. pm SC74 or 744x4 :notworthy: These guys know how to do it and they will be doing more stuff for me soon!!! :rockon: ![]() JP's New Front Bumper!!!! - SC74 - 12-19-2008 Thanks JP :beer: JP's New Front Bumper!!!! - chuzie - 12-19-2008 Your winch is way too clean JP. JP's New Front Bumper!!!! - JayT - 12-19-2008 Well, it has been used once (that we know of)... He has pulled an RV with that thing! Must have gone straight home and polished it up just for us! ![]() JP's New Front Bumper!!!! - JayT - 12-19-2008 Sorry for the HiJack... back on topic... When I do get my EB to that level, I'll be having you guys build a pre-runner front bumper for me... :biggthumpup: |
