my full width axle build 5/23/07->10/28/07 - snipes243 - 10-24-2010 You can do it chuck, at least your not having drop a motor in. Whats the problem with MM not hooking you up with a new cable? my full width axle build 5/23/07->10/28/07 - blazinchuck - 10-31-2010 MM decided not to honor the 36 winches Drew set up for on the mass buy when I got mine. Chuzie being the nice guy that he is...went above and beyond and replaced my 5/16thx100' with 3/8x90'...much stronger(thanks Chuzie!!) He also installed my new LED rock lights yesterday! I over built my front drive shaft that I killed at Harlan, its now a 2"ODx.250"wall thickness!! it aint twisting now! now I need to replace the serp belt and I should be good for URE. my full width axle build 5/23/07->10/28/07 - jollygrngiant - 10-31-2010 Lets see a night shot of those LED rock lights. Are they that much different? my full width axle build 5/23/07->10/28/07 - blazinchuck - 01-09-2011 decided to remove the windshield, that took some serious doing. the PO fully welded the hidge to the body and the WS frame!!!! now I will be able to unbolt the WS and remove it for hardcore places to wheel without damage. Chuzie and I got the dash removed also...but the Mojave heater will not fit!!! so, i will be heaterless for a while. went out there today to remove the rear seat and mount my tool box back in it and found one of the 2 brackets for the traction bar had ripped away from the axle. wasnt very happy when i found that, so i stripped it all down and clean it up and tried it again! hope i got better weld there this time. hope it holds up til i get more stuff for a 4 link. my full width axle build 5/23/07->10/28/07 - broncosbybart - 01-11-2011 depending on what year yours is, the ws frame comes welded to the tub from the factory. only the earlier years had bolts. i have no idea why they changed that. what do you have in mind for the 4 link? my full width axle build 5/23/07->10/28/07 - blazinchuck - 01-12-2011 true the WS hinge was either spot welded or screwed in...but this guy,laid a bead of weld along every edge of that hinge...plus it had spot welds. not sure for the 4 link,i'll probably go with RuffStuff or Ballistic's universal kit my full width axle build 5/23/07->10/28/07 - broncosbybart - 01-12-2011 PO's works on the ws frame sounds awesome.. Bet you put some time into that. I've got about 8-10 ft of 2" .250 wall DOM. Paid $10 a foot for it though... Can measure it if you want me to bring it down. No biggie either way. Ruffstuff had a 20% off year end sale. Ordered a bunch of stuff for the race rig. Still don't have it yet.... my full width axle build 5/23/07->10/28/07 - SC74 - 01-14-2011 Chuck - let's see some pics of your windshield removal - how are you going to take on/off? |
