ParadisePWoffrd's EB - ParadisePWoffrD - 12-01-2011 Here is the 60F that I had been working on some too... got the 4 link brackets welded on. Working on getting the steering setup now. I will probly put a piece of tube between the towers to truss the axle and then tie the knuckles into the truss once i figure out the shock mounting location. ParadisePWoffrd's EB - broncosbybart - 12-01-2011 Been busy, huh? Looking good! I probably have a spare fender or 2 that you could use to stretch your fenders with. both fenders would be damaged, but should be good enough. let me know if you want em. ParadisePWoffrd's EB - ParadisePWoffrD - 12-02-2011 most of that work has been over the last little while... I managed to start widening my trailer deck too... just need to plate it. Ill let you know... I plan to push the axle forward some when i install the 60 w/ full hydro; so I want to wait until then to make sure I dont hack away the whole fender... ParadisePWoffrd's EB - ParadisePWoffrD - 12-18-2011 Moved the gauges up into the dash, in place of the non functional heater controls... took it out last weekend and destroyed everything but 1 stub shaft.... so, today i started the 60 swap... Goal is to have it back together by end of the year for a new years run.... well see also picked up a TBI setup to switch back to gasoline.... its a low priority though ParadisePWoffrd's EB - blazinchuck - 12-18-2011 you know the deal...PICS or it didnt happen lol ParadisePWoffrd's EB - broncosbybart - 12-18-2011 ![]() ParadisePWoffrd's EB - ParadisePWoffrD - 12-19-2011 haha, yeah i know... my phone isnt wanting to upload currently... ill work on that tnite ParadisePWoffrd's EB - ParadisePWoffrD - 12-19-2011 Here is a pic of the moved gauges I had some fan issues, so i relocated it to a puller and added a shroud ParadisePWoffrd's EB - ParadisePWoffrD - 12-19-2011 Here are some pics of the broken shafts so out it came ParadisePWoffrd's EB - ParadisePWoffrD - 12-19-2011 Lastly, pics of the 60 swap: it sitting under the bronco lower links (2x2x0.250) hydro mount and truss 5 lug hubs w/ f150 rotors |
