New Project started today - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Talk (https://cb4x4.com/forum-39.html) +--- Thread: New Project started today (/thread-2783.html) |
New Project started today - 744x4 - 06-25-2011 I cut the rear of the top down also ready for the correct Gap to fill for the Mega Cab. New Project started today - broncosbybart - 06-26-2011 I like it! Keep cutting/welding ![]() New Project started today - SC74 - 06-26-2011 Looks great... if I had known you planned on working on it I would have stayed to help. New Project started today - Crawdad - 06-26-2011 744x4, I see you cut off the back of a 1/2 cab, what kind of condition is it in? Love to have it if you have no use for it. Your bronco is looking great! New Project started today - 744x4 - 06-26-2011 It was a Full top I cut.I wouldnt do that to a Half cab as they are getting harder to find.The back half will be returned to the top after some Mods. New Project started today - Crawdad - 06-26-2011 744x4 Wrote:It was a Full top I cut.I wouldnt do that to a Half cab as they are getting harder to find.The back half will be returned to the top after some Mods. Oh I see now. That one pic looks like you just cut that piece off. Sorry bout that. New Project started today - shon - 06-27-2011 very good job. I need to build me a dolly for a body like yours. New Project started today - 744x4 - 06-27-2011 You can use this 1 if you want after I am done.The Frame it is on weighs 5x what it should though as it is filled with cement like clay for some reason and took 4 of us to carry it.I do have to take the 4 Body Mounts out of the Middle also. New Project started today - NGABronco - 06-27-2011 Great work Keith, most folks don't realize the the top is about 1/2" shorter in the rear, which calls for some "fixin"!!!! That's why I'm doing a soft top, which calls for some "sewing"!!!!! New Project started today - SC74 - 06-28-2011 NGABronco Wrote:Great work Keith, most folks don't realize the the top is about 1/2" shorter in the rear, which calls for some "fixin"!!!! That's why I'm doing a soft top, which calls for some "sewing"!!!!! I bet I can weld better than I can sew! |
