my full width axle build 5/23/07->10/28/07 - blazinchuck - 10-15-2007 you know, that kinda runs me mad...I told them to let me know if I would need anything else for the TRO. I told them about the year and make,model, and axle. So they called back to tell me I would need those. They were only $20 each :evil: my full width axle build 5/23/07->10/28/07 - bucketobolts - 10-15-2007 Matt is the resident authority on knuckle strength and durability :lol: ... my full width axle build 5/23/07->10/28/07 - broncomatt - 10-16-2007 This photo is after pressing the knuckle back on to the ball joints. I had to use a chain to the frame to keep it on. I now keep a spare set of knuckles preped and ready in my trailer. I will say the heim steering lincage is the only thing that kept the wheel from going any farther back than it did. I even tack weld a spot on my ball joints now! ![]() Broncomatt my full width axle build 5/23/07->10/28/07 - blazinchuck - 10-17-2007 IT'S ALIVE!!!!!!! I finished making the new exhaust (super single-Chuckie style) all mandrel bent 2.5" and summit race muffler. This thing sounds BAD AZZ!!!!!! my full width axle build 5/23/07->10/28/07 - ELWOOD - 10-17-2007 we need a sound link..HaHaaaa!! Got any pics of the Chuckie style? my full width axle build 5/23/07->10/28/07 - blazinchuck - 10-17-2007 ELWOOD Wrote:we need a sound link..HaHaaaa!! Got any pics of the Chuckie style?I'll see what I can do...Chuck my full width axle build 5/23/07->10/28/07 - 69bronco - 10-17-2007 Great. Maybe I can come and check it out this weekend. my full width axle build 5/23/07->10/28/07 - krazybronco - 10-17-2007 do you have the axles built yet my full width axle build 5/23/07->10/28/07 - blazinchuck - 10-17-2007 krazybronco Wrote:do you have the axles built yet I have the rear done(it just needs,disc brakes,shock mounts) the front is still out, had to weld some stuff on it. still needs gears reinstalled,knuckles(everything on the knuckles) and all new brakes stuff up front. here's some pics of the exhaust...(anytime Paul 8) sounds great) ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() my full width axle build 5/23/07->10/28/07 - broncomatt - 10-18-2007 Great too hear it runs again. Did you get the rear disk in? Are you worried the exhast will heat up the side wall of your tire? I have a similure setup on mine(pre bent peices welded together, I'm cheap). It actuly melted my fiberglass flare where it comes out. Broncomatt |
