my bronco build pics - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Tech (https://cb4x4.com/forum-40.html) +--- Thread: my bronco build pics (/thread-504.html) |
my bronco build pics - broncomania - 06-28-2008 bought my upper 4 link mounts . ![]() my bronco build pics - broncomania - 06-28-2008 got my 16" coilovers. and lower mounts. ![]() and a box of rockwell parts. boot guards, mohawk pans, pinion brake mounts,and some maltese cross gussets for my cage. ![]() my bronco build pics - broncomania - 06-28-2008 anyone buying rockwell parts needs to go here: http://mudprometalworks.com/home this guy is super cool and his parts are top notch. good prices as well. and he is a bronco owner to. my bronco build pics - cuz1 - 06-29-2008 Mike, Are you using the same body and frame just switching to rockwells? The suspense is killing me.:popc1: my bronco build pics - broncomania - 06-29-2008 cuz1 Wrote:Mike, i will be using the same body and frame . the wheel base will be stretched again from 108.5" to around 115" . im gonna run larger tires but not sure what size yet. :xyxthumbs: my bronco build pics - cuz1 - 06-29-2008 It will be swaaaaaattttt!:notworthy: my bronco build pics - SC74 - 06-29-2008 WOW 115"!!!! Are you going to 4 wheel steering also? Do you think I'll have any trouble at 102" on 40's? my bronco build pics - broncomania - 06-29-2008 SC74 Wrote:WOW 115"!!!! Are you going to 4 wheel steering also? i have 108.5" now with 42's. remember i was running 39.5's before.i would think you should be fine at 102" on 40's . ive seen less on 40's. im not going 4 wheel steering anytime soon. it cost a lot more. :xyxthumbs: my bronco build pics - jollygrngiant - 06-29-2008 Sounds like you'll be busy for a little bit. Can't wait to see pic's of the on-going process!!:popc1: my bronco build pics - broncomania - 07-02-2008 Gubni Wrote:115 seems a bit long, but with 52" boggers it would be about right. Any ideal of a time frame you hope to be done? i hope to get started pretty soon. so far i have about all the parts for the rocks so im gonna rebuild those asap. ive got to get all my link inserts and joints and tube next week hopefully. |
