JohnPaul's Build - chuzie - 07-23-2008 Go get that welder! JohnPaul's Build - johnpaulgolf - 07-24-2008 Ok got all mounts removed and cleaned up and painted...mocked up the rad and taurus fan...need to trim the shroud for the taurus fan and fab some tabs to hang rad...just taking it slow and easy...also rewiring some things I just threw in there and cleaning up the rats nest of wires and still trying to do something temporary for my body mount...run on? ![]() And just a reminder of what's going on in the JP garage.... johnpaulgolf Wrote:Just got the radiator mounts cut off the top...toke out my battery in order to repair bad body mount...and painted my head light rings flat black. JohnPaul's Build - chuzie - 07-24-2008 slow and easy is always the best way to produce quality reliable results. Make sure you are using relays to keep the high current out of the cab if you can. the ... prevented the run on. JohnPaul's Build - jollygrngiant - 07-24-2008 JP, I think your headlight rings look alot better in black than red. Now the F.O.R.D stands out better!!:xyxthumbs: Good work! JohnPaul's Build - chuzie - 07-24-2008 Nice bumper! JohnPaul's Build - manny - 09-01-2008 WOW!!:rubeyes: thats quite a transformation like a episode of overhauling. be very proud of you work on that one it's very nice.:biggthumpup: JohnPaul's Build - johnpaulgolf - 09-28-2008 Allright new winch yall know about but gonna add it to my build thread...:biggthumpup: Also just got the rubber stopper in Fri. and installed!!!:chili: ![]() ![]() JohnPaul's Build - johnpaulgolf - 09-28-2008 I guess I needed a few things for more recovery stuff...added a 4" 8' tree saver by warn...:rubeyes: ![]() :popc1: :popc1: :popc1: :popc1: :popc1: :popc1: :popc1: :popc1: :popc1: :popc1: :popc1: :popc1: :popc1: :popc1: :popc1: :popc1: :popc1: :popc1: :popc1: :popc1: :popc1: :popc1: [SIZE="7"]And My new BADAZZZZ custom Bumper[/SIZE] ![]() JohnPaul's Build - johnpaulgolf - 09-28-2008 Oh yeah almost for got about my new window stickers...matched my old "font" and got new " One Fine 69' " and added some webs in the corners!!!:rubeyes: ![]() Uh Huh!!!:chili: ![]() Yall check previous post for more new new stuff added today!!!:poke: :popc1: JohnPaul's Build - NGABronco - 09-28-2008 Hey jp, that rig is looking good!!! Them ole boys up in g'ville do some nice work, I may need something like that for EB2. Keep up the good work and the pics!!! |
