2009 MEB Bronco Shootout - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: Misc Club Info (https://cb4x4.com/forum-3.html) +--- Forum: Wheeling Events (https://cb4x4.com/forum-16.html) +--- Thread: 2009 MEB Bronco Shootout (/thread-980.html) |
2009 MEB Bronco Shootout - bucketobolts - 04-28-2009 744x4 Wrote:Thats what I thought it was but I popped the cover off the MC and it was only lukewarm to the touch even in the bottom of it.I am going to flush the lines and run some DOT 5 fluid in it and wrap the hard lines and see if it stops this. Flush them good DOT 5 and DOT 3 don't mix well. Do you run power brakes? Vacuum or hydroboost? 2009 MEB Bronco Shootout - broncomatt - 04-28-2009 If dot3 boils in the lines it can cause the wheels to lock up, and only be warm to the touch in the master. Try to rerought the lines or wrap them. Dot 5 may not help with that, and may not react well with the master if its ment for dot 3. I kind of sounds like the pedal rod is adjusted out too much? Sounds like it was still a good trip, wish I could have gone.:banghead::crying: 2009 MEB Bronco Shootout - SC74 - 04-28-2009 Aaron - he's got the stock vacuum booster. It's the stock pedal rod and has worked in the past until this heat issue came up. I think it's just time for a flushing, new fluid, and some heat wrap. 2009 MEB Bronco Shootout - 744x4 - 05-02-2009 They are power Disc brakes using a 77 EB MC and the typical Chevy swap calipers ( 84 Blazer).The Booster is a late 80's Ford LTD booster on a custom Al Bracket that is a exact copy of the EB bracket that worked fine when it was power drum Brakes even with the 77 eb MC. They were touchy when it was 4 wheel drum due to the extra fluid going to them Vs the stock setup. 2009 MEB Bronco Shootout - broncomania - 05-02-2009 where are the pics ??? 2009 MEB Bronco Shootout - SC74 - 05-02-2009 broncomania Wrote:where are the pics ??? back one page... Page 6 I posted some pics of Keith's bronco and our friend's yota truck. 2009 MEB Bronco Shootout - broncomania - 05-03-2009 SC74 Wrote:back one page... Page 6 I posted some pics of Keith's bronco and our friend's yota truck.:beer: |
