mini buildup - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Tech (https://cb4x4.com/forum-40.html) +---- Forum: Build Threads (https://cb4x4.com/forum-11.html) +---- Thread: mini buildup (/thread-1311.html) |
mini buildup - chuzie - 03-06-2015 Always mind the "gap." Good work Sent from my GS3 on Cyanogenmod with the older / better version of Tapatalk! mini buildup - broncosbybart - 03-06-2015 Looking good. The weather should be cooperative this weekend. Get it done! mini buildup - snipes243 - 03-07-2015 chuzie Wrote:Always mind the "gap." Good work I will mind the "gap" Sent from my iPhone using Tapatalk mini buildup - snipes243 - 03-08-2015 Time to drill some spot weld hole ![]() ![]() ![]() Sent from my iPhone using Tapatalk mini buildup - broncosbybart - 03-08-2015 Coming along nicely! I'd be tempted to leave that back angle in place and just flush it up against what is there. I know it looks kinda wonky like but you ought to be able to straighten it up well enough. It would be a good time to remove the pan and cut that bad metal out of the kick panel(s) and put a new patch panel there before welding the floor(s) in. Also, do realize that you are going to make chuzie jealous with all that wire you've got going on. I found an idea for a fuse box today that he might like. mini buildup - chuzie - 03-09-2015 Wow! Just frigging wow. Sent from my GS3 on Cyanogenmod with the older / better version of Tapatalk! mini buildup - snipes243 - 03-09-2015 I will give it til tomorrow at the last to see chuzie's new creation mini buildup - chuzie - 03-09-2015 I'm on the road. Maybe when I get back in 3 weeks. Sent from my GS3 on Cyanogenmod with the older / better version of Tapatalk! mini buildup - snipes243 - 03-09-2015 3 weeks so your say the design will be refined to include Tupperware with latches sounds like a great improvement Sent from my iPhone using Tapatalk mini buildup - chuzie - 03-09-2015 Actually, this is my next addition. Cherokee relay box. Sent from my GS3 on Cyanogenmod with the older / better version of Tapatalk! |
