C'mon with your Flex! - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Talk (https://cb4x4.com/forum-39.html) +--- Thread: C'mon with your Flex! (/thread-76.html) |
C'mon with your Flex! - Ogeechee 4x4 - 04-13-2008 I may as well play, too. I think my rear flexes a bit more than the front, though ![]() C'mon with your Flex! - chuzie - 04-13-2008 I have the same issue. I was told that some of the geometry in the front was off and not allowing for the full flex potential I had in the system C'mon with your Flex! - Ogeechee 4x4 - 04-13-2008 chuzie Wrote:I was told that some of the geometry in the front was off and not allowing for the full flex potential I had in the system That's pretty much what mine needs. Either going with heims at the ends of the radius arms or it's been suggested that i lay the face of the radius arm bracket back. I don't really understand why, i guess it's to let the arm droop more before it binds ![]() But for something that i drive on the street 90% of the time, it's fine like it is. In fact, I'd love to get inspired one day and re-install the sway bars :xyxthumbs: C'mon with your Flex! - Wrenchbender - 04-13-2008 chuzie Wrote:Wrenchbender: Do you usually have a forklift handy? We need to get you on the RTI! Yep its right here all the time, I park it between the house and where I work BTW I walk to work everyday all 250' of it:hysterical: I run a small welding and heavy equipment repair shop for a liv'n in my back yard. C'mon with your Flex! - johnpaulgolf - 04-13-2008 Wrenchbender Wrote:I walk to work everyday all 250' of it:hysterical: I run a small welding and heavy equipment repair shop for a liv'n in my back yard. ......................................................................................................... :brownbag: Sweet...you da man :notworthy: saves on gas money back and forth to work huh. :hysterical::imwithstupid: C'mon with your Flex! - johnpaulgolf - 04-14-2008 chuzie Wrote:I have the same issue. I was told that some of the geometry in the front was off and not allowing for the full flex potential I had in the system yeah whatever :banghead: mine don't flex in the front either :crying:...blah blah blah blah... but here is another look :hysterical::hysterical: click thumbnails for more of me ![]() ![]() ![]() ![]() ![]() ![]() C'mon with your Flex! - johnpaulgolf - 04-14-2008 Once again...I'm sorry but proud too.:toothy12: johnpaulgolf Wrote:Wow stock Suspension with 3" body lift. :rubeyes: What Chuzie?..."stock" as far as I know stock height anyway with new shocks that are'nt right. :hysterical: chuzie Wrote:Stock? Come on. what? C'mon with your Flex! - chuzie - 04-14-2008 You funny mister. ![]() C'mon with your Flex! - smooth - 04-14-2008 Okay, here's what I got: ![]() ![]() C'mon with your Flex! - jollygrngiant - 04-14-2008 Nice flex!! Is that a 20 degree ramp? |
