Broncitis Rat Rod build thread. - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Tech (https://cb4x4.com/forum-40.html) +--- Thread: Broncitis Rat Rod build thread. (/thread-3843.html) |
Broncitis Rat Rod build thread. - Broncitis - 12-07-2015 I was just about to purchase the kit from BC and then I saw the 20 $ shipping and backed out. The kit is reasonably priced at under 37.00. I refuse to pay that hi of shipping. What is wrong with a if it fits it ships box from the USPS? Reckon I am back to fabbing my own. Broncitis Rat Rod build thread. - broncosbybart - 12-07-2015 The biggest thing you'll be up against in making your own kit is the DOM tube used for the sleeves. If you can source something for that, you're good to go Broncitis Rat Rod build thread. - Broncitis - 12-15-2015 broncosbybart Wrote:The biggest thing you'll be up against in making your own kit is the DOM tube used for the sleeves. If you can source something for that, you're good to go ![]() Sent from my NEC-NE-201A1A using Tapatalk Broncitis Rat Rod build thread. - snipes243 - 12-15-2015 Careful putting a plate between the box and the frame it will change your drag link length. Sent from my iPhone using Tapatalk Broncitis Rat Rod build thread. - chuzie - 12-15-2015 The biggie is making some reinforcement tubes on between the frame. Easily done but easily forgotten Sent from my GS3 on Cyanogenmod with the older / better version of Tapatalk! Broncitis Rat Rod build thread. - Broncitis - 12-15-2015 ![]() ![]() Sent from my NEC-NE-201A1A using Tapatalk Broncitis Rat Rod build thread. - Broncitis - 12-16-2015 OK I give up. Has anyone found a alternative to WEst Texas for rebuilding the Steering Sector? Broncitis Rat Rod build thread. - chuzie - 12-16-2015 Clay should know considering his recent experience. Broncitis Rat Rod build thread. - Broncitis - 12-16-2015 Anyone know which year F 150 4x4x2 box to use to do that conversion. Broncitis Rat Rod build thread. - chuzie - 12-16-2015 http://www.wcb4x4.com/tech/diyrockcrawler.shtml Sent from my GS3 on Cyanogenmod with the older / better version of Tapatalk! |
