what have you wrenched on your bronco(s) today? - Timstrk - 07-12-2014 Didn't hurt anything behind the core support. Cosmetic. Caved in the grille. Fixed the marker light bucket but still need the lens. The strip on the hood is the top trim piece for the corral molding. The center of the hood was jacked up about a foot and cracked in the center. Fixed that with braces on the bottom side. The plates backing the hood pin hole cover the splits in the hood at that point. A little heavier but solid again. what have you wrenched on your bronco(s) today? - snipes243 - 07-16-2014 Not sure if my fan is big enough Sent from my iPhone using Tapatalk what have you wrenched on your bronco(s) today? - chuzie - 07-16-2014 Is that a 14"? what have you wrenched on your bronco(s) today? - snipes243 - 07-16-2014 16 Sent from my iPhone using Tapatalk what have you wrenched on your bronco(s) today? - chuzie - 07-16-2014 And u seriously don't think it's big enough or ur being sarcastic? what have you wrenched on your bronco(s) today? - wepuckett - 07-16-2014 I focused on getting everything off the frame to prep it for media blasting but got stuck on the last to body mounts the bolt is broken off so can't pull the bolt and tap them out. Tried to drill the bolt out but drill bit broke tried to use cut off wheel but too much rubber in the way to get to the sleeve or bolt. Any suggestions would be greatly appreciated. what have you wrenched on your bronco(s) today? - chuzie - 07-16-2014 Torch the rubber first. what have you wrenched on your bronco(s) today? - snipes243 - 07-16-2014 chuzie Wrote:And u seriously don't think it's big enough or ur being sarcastic? Can a fan be to big? Sent from my iPhone using Tapatalk what have you wrenched on your bronco(s) today? - chuzie - 07-16-2014 snipes243 Wrote:Can a fan be to big?Ur drunk. what have you wrenched on your bronco(s) today? - snipes243 - 07-16-2014 Nah Sent from my iPhone using Tapatalk |
