sterlin 10.25 - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Talk (https://cb4x4.com/forum-39.html) +--- Thread: sterlin 10.25 (/thread-1245.html) |
sterlin 10.25 - blazinchuck - 02-16-2009 im having a hard time trying to find a full spool for this axle. what gives?? i dont want a detroit...thanks sterlin 10.25 - blazinchuck - 02-16-2009 wow, i think i just found something on FSB that says the 10.25 has no one making a spool for it. sterlin 10.25 - DeTowman - 02-16-2009 weld it!!! I don't really care for the sterling, i've got a Dana 60 if u need it...:rebel::xyxthumbs: sterlin 10.25 - SC74 - 02-16-2009 if you were going for a spool you might as well weld it like Dean said. sterlin 10.25 - broncomania - 02-17-2009 they dont make a spool for a 10.25 sterlin 10.25 - blazinchuck - 02-17-2009 so what else are you sterlin guys running? sterlin 10.25 - 66bronco - 02-17-2009 Chuck, I am going to be running a 10.25 with a 7018 spool by Lincoln. :hysterical: bryan sterlin 10.25 - johnpaulgolf - 02-17-2009 :popc1: . sterlin 10.25 - blazinchuck - 02-17-2009 welded it is then! |
