WR Thompkins - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Talk (https://cb4x4.com/forum-39.html) +--- Thread: WR Thompkins (/thread-2038.html) |
WR Thompkins - wr thompkins - 01-14-2010 I am restoring an uncut 75 and would like some tire and wheel info. I have 1 inch susp. and 2 in body lift. I want to put Taller tires with mild tread. I think 16 inch would be good. I have a set of 16 inch stock steel wheels I took off a 64 Scout that are aprox 5.5 or 6 inches wide, with very little offset. If I go with these and some Tall/narrow m/s tread I think I will have rear fender clearance I need. I put 31-10-15 on some jeep wagon wheels and they scrubbed on the rear . They had too much offset. I would like to find 16 in. aluminum Ford style wheels that would work. Has anyone used this combination or if you have any suggestions I would appreciate any information. Thanks WRT WR Thompkins - SC74 - 01-14-2010 Can't help much on this, but MillKnob should chime in soon and he's running uncut rear fenders with tall and skinny tires. WR Thompkins - 66stocker - 01-14-2010 I believe Mill Knob is running 33 X 9.50's on stock steel wheels. I think he has about 3" of susp lift but I'm not exactly sure. Mill ??? Where ya at buddy? WR Thompkins - ELWOOD - 01-14-2010 i think he said it was a 2.5 inch lift with 33x9.50 bfg at ko. I like the look too. My sons bronco is uncut. It's gonna have a 3.5 inch. I have some 33x10.50 bfg km2 on stockers and Mr. Jp's hubcaps. WR Thompkins - 69bronco - 01-15-2010 I am running 31 10.50s with a 3.5 lift with no problems (uncircumcised :bdent::xyxthumbs ![]() ![]() WR Thompkins - wr thompkins - 01-17-2010 Thanks for the reply, Mine sat just like that until I put the hardtop on and replaced the complete floor with 11 ga steel plate and it settled about 1.25 inch and now it hits on bumps and turns. I have stock crome Jeep wheels from a 84 Scrambler on it ,the offset is more than the stock bronco steel wheels. I think I will swap back to the stock bronco wheels. I also have some 16 inch narrow steel wheels from a 64 Scout that might get me where I want to be with some 235/or 245 /16s. Thanks for the info WRT WR Thompkins - Mill Knob - 01-17-2010 66stocker Wrote:I believe Mill Knob is running 33 X 9.50's on stock steel wheels. SC74 Wrote:Can't help much on this, but MillKnob should chime in soon and he's running uncut rear fenders with tall and skinny tires. You are both right. I am running skinny tires on my ride. I am running the 33x9.50 bfg's but they don't make them any more. I believe that you can run the 10.50 bfg's and your fenders will clear it. I am running 2.5 inch lift with no body lift. One day when the bfg's are wore out I plan on running a set of 32 or 31's. Hope this help. I will try to get some pictures up for you soon. WR Thompkins - wr thompkins - 01-17-2010 Thanks for the response I am going to try my 16/6 scout wheels with 245x16s Thanks again WRT |
