78 f150 - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Talk (https://cb4x4.com/forum-39.html) +---- Forum: Non Bronco Tech/Talk (https://cb4x4.com/forum-8.html) +---- Thread: 78 f150 (/thread-2320.html) |
78 f150 - firefighter2134 - 08-25-2010 thought i might throw this out there for anyone. a guy i work with has 78 f150 with 351m. c6, engine only has 1800 miles since it was put back together. when he puts it into gear it stalls out. but if he revs engine slightly it will run fine. it is idleing fine. just when tranny is engaged. he just changed tranny fluid and filter and fuel pump and hoses. changed valve covers and gaskets. hes not running a tach so rpms are a guess. thanks 78 f150 - blazinchuck - 09-14-2010 maybe timing needs bumping? 78 f150 - sparkchaser - 09-14-2010 x2 on the timing or maybe a vacuum issue. 78 f150 - firefighter2134 - 09-14-2010 i will see him tomorrow and let him know. thanks |
