Helicoil tap and tool - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Talk (https://cb4x4.com/forum-39.html) +---- Forum: Non Bronco Tech/Talk (https://cb4x4.com/forum-8.html) +---- Thread: Helicoil tap and tool (/thread-891.html) |
Helicoil tap and tool - chuzie - 07-28-2008 I need to repair one of the pan bolt holes on my C4 (5/16-18). Thinking about going the Helicoil route but I have no intention of paying 30.00 to make a single thread repair. I think I could probably make the installation tool out of an old flathead screwdriver with a slit cut in the blade. I really need to know if the taps that come with the kits are a special pitch thread or something standard that I would have in my collection of taps. Thx. Helicoil tap and tool - blazinchuck - 07-28-2008 what size is the original bolt hole? I might have the correct heli kit at work and you could get it with the jack. Also the heli's are a completely different tap size. Helicoil tap and tool - chuzie - 07-28-2008 the original c4 pan bolt hole size is 5/16-18 |
