What to uses??? - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Talk (https://cb4x4.com/forum-39.html) +--- Thread: What to uses??? (/thread-976.html) |
What to uses??? - Mill Knob - 08-27-2008 I am in the middle of replacing my inner fender,fender well, and kick panel.. I was wanting to know what i should put back as a coating??? I really do not want to load it up and take it to a body shop to have it primer and painted... So i thought about using POR15 to coat my new metal. But want to know what else there was out there that i could do it my self???? Any ideas would be great...:beer: What to uses??? - Traveler - 08-27-2008 We have not had good luck with POR 15 at all. I am thinking of using Rustoleum under and inside the EB. It is quick, easy, cheap and looks good when brushed on. Painted our trailers with it and they sit out in the weather. They still look really good, but Rustoleum does not hold up well to rock chips, so it will need touch up. What to uses??? - DeTowman - 08-27-2008 there's a guy on wheelindixie that sells this stuff called als liner its like rino liner...cheap 2 ....i'm thinkng of trying it...http://www.tscoating.com/ |
