'77 Bronco 4bt Conversion
#41
Started the fabrication process for the Art Carr shifter mount & covers. Plan to lower it about 3/4" when the bends are made near the floor. Keeping it narrow for the time will probably require side bracing. But don't want to do anything long term for the moment. Would really like to build a storage box off to the side.... but I'm sure that will be way into the future.
sssaaaawwweeeeetttt
Removed the dash and rebuilt the heater box as many have done with a Cheby blower fan, new seal kit, new heater core and paint. Repaired the torn duct with GOOP adhesive.. will see how it works out.
Here's some photos of the dash that has been modified. Need to confirm all of the gauge & switch locations and recut the dash. Please let me know about your thoughts about the gauge locations I have mocked up. The tach is mounted to the column. Thanks
those shifters are the stuff. im gonna have to get me one after i get all this other stuff done.
Here's a photo of the dash and the gauges. I had to move the gauges on the right to clear the defrost ducting. Still need to drill (3) holes for the turn signal indicators and high beam indicator lights.
Looking good dude, looking good!!!:xyxthumbs:
Nice dash!! Love the guages:xyxthumbs:
Nice...can't wait to see it!!
Here's some photos of modifications to my Art Carr shifter to add a backup light switch. I purchased a 2nd switch (same as the safety start park switch) and modified the bracket by bending the switch location 90 degrees and modified the tab by bending a radius to work in that plane. In addition there are photos of the completed metal enclosure for the shifter and wiring harness with connector.
  Bronco Camo Wraps circlefire 7 3,573 03-27-2018, 05:20 PM
Last Post: circlefire
  68 Bronco wepuckett 126 33,305 04-27-2017, 09:57 AM
  73 Bronco wepuckett 115 28,921 05-17-2015, 11:11 PM
  That storage locker Bronco 66Roadster 53 14,041 01-17-2015, 11:49 AM
  Wheels and Tires. Stock 1996 Bronco 5.8L 4wd or w/ 2" lift and poly body mounts. jrshepherd 2 2,481 05-10-2014, 02:36 PM
Last Post: Wickedlester
  1969 Bronco Build jtoney51 9 4,325 07-09-2013, 10:26 PM
  66 Bronco rebuild Casey835 56 14,906 06-04-2013, 07:45 AM
  my bronco build 66bronco 65 18,886 04-17-2012, 11:54 PM
  Just getting started 74 Bronco N747JB 7 3,066 10-29-2011, 07:59 PM
Last Post: N747JB
  BC Bronco shorty header install with 2-in-2 exhaust Crawdad 14 6,586 01-04-2011, 02:03 PM
Users browsing this thread:
