Dodge in need...
well, I called the dealer about the fuel line:banghead:$62 for a short 10" hard line-haven't ordered that, but I did buy 2 new interstate mega-tron batteries($160):rubeyes: I'll install them tomorrow,Chuck
Are you talking about the plastic hardline or the metal?
I was able to modify all the plastic hardline on my. You can remove the locking fittings and move them down the line as you see fit with a little heat. I was even able to reform some of the lines too. Gotta be careful not to overheat or the line becomes too brittle and may burst under constant fatigue.
this one is metal with a banjo fittings on both sides. it split open and we cut the bad spot out and sleeved it with fuel line for a repair. guess I will have to fix it soon.
Yep. You're screwed. Lay down some $$$ and pay the piper.
well, the dodge never let me down on the Tenn. trip a week ago. I got 12mpg on the way up/ and 12.5 on the way home(330 miles-1 way). The added horsepower/torque came in handy. I hit the Saluda grade(7 %) with plenty of pedal and power to spare. The highest EGT was 1250 degrees and right at 40 psi boost. I'm guessing I was still around 15,000 lbs. DODGE CUMMINS!!!!!!
since the 3" exhaust fell off(broke) right in front of the axle(not weldable)...I ordered a complete from turbo back...5" straight system!!! installed it today. This is BADDAZZ! John(mudmonkey) even came by. Cant wait to jump on someone now...should run awesome!!!!
That's gonna kick some tail! I'll have to yield when I see you coming.....or just floor itSmile
