03-26-2010, 12:09 PM
i have been havin a rattle out of the two rear doors. i have tried adjusting both the pin and the latch with no luck so her is what i ended up doing
i got some 3/8 od fish tank type hose from the local hardware for $.25/ft. i got 30 ft for 2 doors.
first remove the sill panel. it just clips on.
then mark the split in the seal. remove seal. it just pulls off.
i didnt have a fish tape so Nut brouoght me by some 10ga hard wire. i used soapy water as lube and inserted the wire. taped it to the tube and pulled it through keeping it soapy.
fixed
fixed
Eric. :rebel:
