Merry F'n Christmas
i have been havin a rattle out of the two rear doors. i have tried adjusting both the pin and the latch with no luck so her is what i ended up doing
i got some 3/8 od fish tank type hose from the local hardware for $.25/ft. i got 30 ft for 2 doors.
first remove the sill panel. it just clips on.
then mark the split in the seal. remove seal. it just pulls off.
i didnt have a fish tape so Nut brouoght me by some 10ga hard wire. i used soapy water as lube and inserted the wire. taped it to the tube and pulled it through keeping it soapy.
[Image: doorfix01.jpg]
[Image: doorfix02.jpg]
[Image: doorfix03.jpg]
[Image: doorfix04.jpg]
[Image: doorfix05.jpg]
[Image: doorfix06.jpg]
[Image: doorfix07.jpg]
[Image: doorfix08.jpg]
[Image: doorfix09.jpg]
[Image: doorfix10.jpg]
[Image: doorfix11.jpg]
[Image: doorfix12.jpg]
[Image: doorfix13.jpg]
[Image: doorfix14.jpg]
[Image: doorfix15.jpg]
[Image: doorfix16.jpg]
[Image: doorfix17.jpg]
[Image: doorfix18.jpg]
fixed
[Image: th_fixed.jpg]
Eric. :rebel:
That's using your noggin' for something other than a hat rack...great job!
this has actually worked great!! the tube is not tight in the WS so it still seals the door well. all this does is add a little stiffer resistance when the door is shut. this woulld work with just about any vehicle with this type weather stripping.
Eric. :rebel:
Nice work. Awhile back nissan had a simular problems with the quest. As part of the recall we put a small slice in the door seal and slid a section of rubber hose into the seal.
Glad you got yours fixed.
