Threads: 77
0
scbronco Wrote:right now its semi uncut... i trimmed the inner lip and about 1 inch of the molded flare out to test fit the panels while the tires were still on. i originally planned to do a full cut with warflares. to fit my suspension and usage plan (3.5"SL 2"BL 35" tire, and 60% offroad use) it needs to be cut, but it does look good the way it is... its gonna get cut though... jigsaw is at the ready
mokin:
yes, i masked, then i masked, then i masked again... thank gooodness thats done...
I sorta like it "semi-uncut". I'd wait till you have all the lifts and tires on before cutting. You could start a new thread on Classic and call it:
Any Semi-Lubrs Out There?!!!":beer:
Threads: 141
0
if you decide to cut more, here is a little hint- get a 4-1/2 inch angle grinder if you don't have one already and buy some really thin (0.045') metal cutting wheels for it. that would work a lot better than a jigsaw. i put masking tape over the wheel opening and draw the outline of the fender flare on it with a marker. then i make another mark about 1 to 1.5" inside of that line and that is what I cut. That way you have a pretty tight fit without a lot of metal protruding from behind the fender flare when you are done. You just need enough for the rivets.
Threads: 141
0
i agree w/crawdad as well. wait till the body is on the chassis. you can cut it at any time now.
Threads: 141
0
looks great! you have your work cut out for you. 1.5" will be fine. no worries there. are you going to build some brackets to attach it to the frame?
Threads: 77
0
Looking like a good start! I have a lot of sanding on mine to do. Might get someone else to do it and the inside of my bronco.
Threads: 133
0
wow ! nice build up.
