lowered EB streetrod...
yeah..thats behemoth's rig
but im really leaning toward a street rod look...skinny/fats! tub'd out hotrod!!!
went to a swap meet today and scored a narrowed 9" housing!!! doesnt have any shafts...but i'll get some new ones cut
cool stuff. i like the direction that you are heading.
heres a pic of the narrowed nine
where should i get axle shafts from...moser? strange? gimme some ideas guys
blazinchuck Wrote:heres a pic of the narrowed nine
Dude, that thang is tiny. you check with Whamo.Confusedupergrin:
There's nothing "long" about that axle!
The Blue one that was @ the Super Celebration last weekend used the stock frame but removed all the coil stuff up ft and the top of the A arms were right above the top of the frame.The Rear had a c-Notch cut into it to allow the Ass to drop.I made Robert crawl under it to check it out.You wouldnt have to run that much C-notch if you used a 4 link and some airbags in the rear though.I believe there were no Body Bushings@ all just the frame to the Tub. To bad he was running a Chevy Motor in it,Killed the theme with a SBC in there.
both make good axle shafts chuck.
Aaron bought the rolling chassis and brought me another frame to build with. so far i removed the coil buckets. still have a lot to remove...gonna be slooooooow process
still collecting parts...
so far i scored a '98 explorer 8.8 with disc,sway bar,and 4.10s
just got back from summerville and bought a AOD from a 87 f150. looks brand new...was told it was a fresh rebuild, and hasnt been run since..we will see
