'78 F250
Picked up the block and crank today. Won't have time to work on it this weekend. Big Grin I'm still looking for a Performer 400 or Weiand Action Plus manifold. I'm also in the market for a MSD dizzy, 351C/429/460 will all work.
whats the latest on this build?Chuck
Got to get over to my buddies to take his A frame apart. Going to pull the the cab, fix the a couple little places, and bedliner the inside. Also going to shoot the chassis with a good coat of paint. I'm going to change all the fuel and brake lines while the cab is off.
Figure if I'm going to make her a keeper, I'd better do it right. 8)
Sounds like you're doing it right. can't wait to see the finished product! Big Grin Big Grin Big Grin
Check out my rims I scored this morning. 8)
[Image: 114-1444_IMG.jpg]
Also have the short block together. I degreed the cam and have my lifters soaking. Will have the heads on soon. Still need to pull the old engine to see if the pick up is any good. Also need the main bolt out of it with the stud for the rear sump pan. I acquired a Mallory Unilite distributor and an Edelbrock manifold.
[Image: 113-1310_IMG.jpg]
that is gonna be Bada$$!!!!! :twisted:
the better have a video of this thing doing a burn out after you get that bad motor in
Good ole slotted mags, easy to clean and tough as nails, you can't do much better than that!! Smile Smile
Picked up a set of Ford Racing valve covers with all the accessories for $45.
[Image: 114-1461_IMG.jpg]
  f250 End Links jrshepherd 2 1,702 11-06-2011, 10:07 PM
Last Post: jrshepherd
  '76 F250 bucketobolts 6 1,752 09-04-2008, 07:59 PM
Users browsing this thread: 16 Guest(s)
