ParadisePWoffrd's EB
#61
Here is the 60F that I had been working on some too... got the 4 link brackets welded on. Working on getting the steering setup now.
I will probly put a piece of tube between the towers to truss the axle and then tie the knuckles into the truss once i figure out the shock mounting location.
Been busy, huh? Looking good! I probably have a spare fender or 2 that you could use to stretch your fenders with. both fenders would be damaged, but should be good enough. let me know if you want em.
most of that work has been over the last little while... I managed to start widening my trailer deck too... just need to plate it.
Ill let you know... I plan to push the axle forward some when i install the 60 w/ full hydro; so I want to wait until then to make sure I dont hack away the whole fender...
Moved the gauges up into the dash, in place of the non functional heater controls...
took it out last weekend and destroyed everything but 1 stub shaft.... so, today i started the 60 swap...
Goal is to have it back together by end of the year for a new years run.... well see
also picked up a TBI setup to switch back to gasoline.... its a low priority though
you know the deal...PICS or it didnt happen lol
Confusedtupid:
haha, yeah i know... my phone isnt wanting to upload currently... ill work on that tnite
Here is a pic of the moved gauges
[Image: attachment.php?attachmentid=4929&d=1324335531]
I had some fan issues, so i relocated it to a puller and added a shroud
[Image: attachment.php?attachmentid=4928&d=1324335531]
Here are some pics of the broken shafts
[Image: attachment.php?attachmentid=4918&d=1324335029]
[Image: attachment.php?attachmentid=4919&d=1324335029]
[Image: attachment.php?attachmentid=4920&d=1324335029]
[Image: attachment.php?attachmentid=4921&d=1324335029]
so out it came
[Image: attachment.php?attachmentid=4922&d=1324335085]
Lastly, pics of the 60 swap:
it sitting under the bronco
[Image: attachment.php?attachmentid=4923&d=1324335203]
lower links (2x2x0.250)
[Image: attachment.php?attachmentid=4924&d=1324335203]
hydro mount and truss
[Image: attachment.php?attachmentid=4925&d=1324335203]
[Image: attachment.php?attachmentid=4926&d=1324335203]
5 lug hubs w/ f150 rotors
[Image: attachment.php?attachmentid=4927&d=1324335203]
Users browsing this thread: 26 Guest(s)
