clutch help please79 bronco
Ok ive got a 79 bronco the clutch went out today don't have a clue what im doing here if u know anything that will help please let me know
sorry, most of us were out for the weekend with our CB4x4 event/URE trail run. did you get it figured out? what is going on? did it just quit working (slipping) or does it not disengage when the pedal is pushed down? I assume that the linkage is still working properly.
It is making a really loud noise when in gear and vibrating when u push the clutch it stops the noise and vibration the pedal changed too I have been working on finding the best way to take on the clutch and after alot of research ive decided to pull the motor to get to the clutch now I have to get a cherry picker
Sounds most likely that the throw out bearing is shot. You can either pull the engine or the trans. Might be easiest to do the engine. The trans and t-case are very heavy!
I have decided to pull the motor I just have to get a cherry picker now u know where I can get one cheep
probably harbor freight. not sure if there is one up your way or not. craigslist would be my choice for trying to find a used one.
I borrowed one gonna start on it in the am any tips or tricks that will make it easier
have any luck?
Not much my back is out again so im moving slow today
Not yet my back is shot so not moving too good today
  Latest Bronco Driver Cameo Bronco Biff 9 2,871 05-10-2017, 11:55 PM
  what have you wrenched on your bronco(s) today? firefighter2134 2,039 256,630 03-27-2017, 11:17 AM
  Bronco sighting in eastern Pendleton SC Crawdad 0 1,410 01-15-2017, 10:06 AM
  Bucking Bronco ParadisePWoffrD 0 788 01-18-2016, 12:18 PM
  Bronco new year resolutions wepuckett 12 2,541 01-03-2016, 11:52 AM
  Check this bronco out snipes243 5 3,249 12-29-2015, 08:58 PM
  Bronco Christmas snipes243 23 4,100 12-26-2015, 04:22 PM
  Who's Charleston Bronco made my local news? Bronco Biff 0 768 10-05-2015, 08:58 AM
  The Bronco made the news today snipes243 8 1,922 08-24-2015, 12:45 PM
  Not a bronco but..... firefighter2134 4 1,494 07-11-2015, 10:10 PM
