Yesterday, I put on new exhaust with some sound to it. Today I'm putting in new master cylinder, so brakes will stop locking up. Hope that does it.
MyForth Wrote:Yesterday, I put on new exhaust with some sound to it. Today I'm putting in new master cylinder, so brakes will stop locking up. Hope that does it.
cool, we need a sound clip cmon!
Revised the tie-rod on the crawler, fabbed new radiator mounts, added some heat shield, welded a tab for a radio antenna, and worked on the front bumper.
Got back from URE on Saturday. Pressure washed the heck out of it inside, outside, and underneath. We did some litter clean up and the interior smelled like death warmed over.
Sunday I tore the nose and doors off of it. Going to do some major body work to it to get it looking really nice again.
Pics of the progress:
These fenders might look familiar to Crawdiddy. Putting them to good use! They were rough around the edges, but I think they will fit the bill. Had to cut them some more. The grille isn't perfect either, but should get the job done well enough. I can't make it too nice...
Some more progress:
Front end still needs some more cleanup and alignment work. I had to fix several of the mounting holes on the DS fender. The PS fender was better, but still needed some work. Both had some cracks that needed to be welded and ground down.
I wanted to do away with the aux fuel opening as it looked really dumb with the flare running through the middle of it. The patch panel isn't welded in yet (the trigger cord on my welder quit), but you get the idea.
That's all for now.
Not mine, but got another one done. One of the guys near me scored this awesome gem. Now it has a new engine/trans in it. He wanted me to button it up.
Gettin replacement engine ready for install. posted pic on build site. Dirtywhiteboy
Although not bronco related, I spent 7 hours replacing water pump and thermostat on the fiancee's 03 Beetle. I should have bought a whole rebuild kit for that process. Saved $700 by doing it myself though. Thats like making $100 per hour...
finished puting all the bolts in the roll cage today,tommorrow gona try to put the e-brake brackets on the tub.
  Latest Bronco Driver Cameo Bronco Biff 9 3,608 05-10-2017, 11:55 PM
  Bronco sighting in eastern Pendleton SC Crawdad 0 1,589 01-15-2017, 10:06 AM
  Bucking Bronco ParadisePWoffrD 0 945 01-18-2016, 12:18 PM
  Bronco new year resolutions wepuckett 12 3,235 01-03-2016, 11:52 AM
  Check this bronco out snipes243 5 3,681 12-29-2015, 08:58 PM
  Bronco Christmas snipes243 23 5,326 12-26-2015, 04:22 PM
  Who's Charleston Bronco made my local news? Bronco Biff 0 974 10-05-2015, 08:58 AM
  Ruff 76 I looked at today. Broncitis 20 6,843 09-05-2015, 08:49 PM
  The Bronco made the news today snipes243 8 2,444 08-24-2015, 12:45 PM
  Not a bronco but..... firefighter2134 4 1,854 07-11-2015, 10:10 PM
